Newbie Needs Help (camchain Off Crank)!!
Discussion in 'Newbies Hangout' started by antreas skourides, Dec 7, 2018.
  1. antreas skourides
    Connecticut, USA
    Happy new year by the way!
    #21
  2. Wishbone
    Wishbone First Class Member
    Essex UK
    possibly a connection at Starter?
    You have turned the engine over by hand to see it is running free?
    #22
  3. Wishbone
    Essex UK
    If it is running free, just use a jumper from battery live to starter feed and see what happens.
    #23
  4. Sprinter
  5. antreas skourides
    Connecticut, USA
    Update: i have 12.8v going to the starter motor when I press the starter button. Next step is to remove the starter and check it. It's weord because it was working before disassembly...
    #25
  6. antreas skourides
    Connecticut, USA
    And the engine turns freely.
    #26
  7. antreas skourides
    Connecticut, USA
    Thanks! I'm trying my best. It should be on the road soon. The best part of the story is that now I know the engine inside out! At the moment I'm getting educated on the electronics !
    #27
  8. Arno triple
    Arno triple Senior Member
    You can try removing starter and, once firmly fixed on your workbench, connect power directly from external battery. Just to make sure starter is fine.
    Btw: does your voltage drop when you try to start? If not: starter failure.
    #28
  9. antreas skourides
    Connecticut, USA
    Yea
    H, that's what I'm doing next. That would be a 5 minute job but I have to drain the oil, remove the exhaust, etc, so i can remove the starter...
    #29
  10. Sprinter
    Can you short across the starter to start it ,then eliminate it for the equation, without removing.
    #30
  11. joe mc donald
    Antreas.
    When you rebuilt that head you did pour some oil in around the chain and the lobes this lubricates and eases first start so as it doesn't start dry. You have checked all the relays you say like the clutch switch and side stand. And made sure the bike is in neutral. Did you try rocking it back and forth in a gear just to ensure the engine is free or perhaps try a bump start if you are confident the bits in question are all free but make sure the clutch is free before again by rocking in gear to free the plates. You have done all the hard work so I'm sure you will be there in no time atall. Keep us all in the know.
    Regards
  12. Sprinter
    Is it earthed??
    #32
  13. Callumity
    Your battery may have died off the bike....
    What voltage reading do you get between the battery terminals with the starter button depressed? It gives a rough idea of the amps being drawn and if it sinks below about 9.5v your battery either needs charging or replacing.
    #33
  14. antreas skourides
    Connecticut, USA
    Hello everyone, Thank you for your support. I removed the starter and tried it. It was dead, so I opened it up. It was full of oil!! My first thought was that the shaft seal failed. And I was right. I closed it up again, placed it upright and poured some penetrating oil on the shaft and seal.
    The oil just went in the starter motor. I called my local Triumph dealer who told me I had to purchase the complete starter motor ($800) !!! hahahahahah. After a few hours of research I found out that the shaft seals on those denso starters are made by NOK.
    However, you cannot find a replacement using the part number that's on the seal (ACO5821). After going through some cross reference books, I found out that there is a replacement by Denso and the part number is 949150-1660. I will know for sure when I receive the items.
    I bought 3 seals just in case and the cost was $6 per seal (plus 9$ shipping- I also bought the brush assembly (hoping it's the same).
    I took a few photos so that everyone understands what I'm talking about but my daughter dropped my phone in the oil pan (which was full of oil) so now I need a new phone! lol
    #34
  15. antreas skourides
    Connecticut, USA
    Battery is brand new and was checked. Thanks
    #35
  16. antreas skourides
    Connecticut, USA
    Yes I checked that too.
    #36
  17. Wishbone
    Essex UK
    I t just seems to get better for you, and now the Phone!!
    How much are the seals for that? hope it aint an Iphone!!
    At least its getting close to running. Good luck with the starter refurb.
    #37
  18. antreas skourides
    Connecticut, USA
    Update: could not wait for the seals to arrive (1 week) and went through my parts containers and found a honda cb550 kick starter seal that was the same size. It worked perfectly. Now the starter is back on the bike.
    I will put some oil and gas and give it a try!
    Thanks everyone!
    #38
  19. TEZ 217
    Ha Ha you seem a very practical guy no matter what comes your way, although I cant help with your problems I am enjoying reading this and look forward to your updates good luck Sir
    #39
  20. Tiglet
    Fingers crossed that she’ll fire up and run like a dream.
    You sure could do with some good luck to start the New Year :sun:
    #40
