Battery Failure - Again - When Starting
Discussion in 'Newbies Hangout' started by Jonathan Copping, Feb 19, 2020.
  1. Tigcraft
    It thinks a bit like a ’sell by date’ as we all know is bollocks. Well you can either live with it and let it piss you off till you sell the bike, or keep putting new batteries on OR have a can -bus modification done that’s reversible if you sell the bike
    Follow this post i made last year on here Sorry as I don’t know how to make a link. Just paste it in search
    Can- Bus Starter Bypass Bonneville
  2. Tigcraft
  3. Easy Tiger
    Easy Tiger Elite Member
    Jan 2, 2020
    1,604
    Wirral England
    Hi DD
    I can see how that can happen with the condensation, but luckily it hasn't happened so far. I haven't ridden the bike for over a month now with this rubbish weather, and if I hadn't have started it each week for about 30mins and is up to temp, the battery would be flat now. but as It started the other day, all is well, and no water in the oil. I will be looking at an Optimate 4 it does sound a lot better. :)
  4. Dartplayer
    Hi Jon and welcome to the forum :cool: Optimate charges are great for the offseason, looking forward to seeing your ride
  5. Bad Billy
  6. Helmut Visor
    Hi Jon, and welcome in :cool::cool:
  7. Tiglet
    Hello Jon and welcome to the forum :)
  8. Jadorff
    Jadorff Noble Member
    Apr 14, 2019
    879
    Adelaide Australia
    Hi and welcome i had 2 batteries fail then the bike would not start i couldnt find the promblen would turn over battery flat in a few seconds got an auto Electrication and had a short to earth on the clutch switch he ran a new earth cut out the lead that tells the computer the battery is under 12volts and now the bike can sit for weeks and will start. before the short happened wouldnt start if it sat for a week if you look it up the bike will not start if the volts drop under i think it is 11.9 volts tells the copmputer there is not enough volts i have a t100 2008 bonniville
  9. Jonathan Copping
    Jonathan Copping New Member
    Feb 19, 2020
    4
    Sevenoaks
    Update! - Just had it serviced at Laguna, and MOT'd. They noticed battery was not charging properly and have to order a part at £339 from Triumph. I'm not technical but the description reminded me of the old Ignition coil. Bit miffed, especially as the whole bill will be around £900 with a new rear disc... The whole bike still looks new and only done 12,000 miles.. I wonder if anyone other owners have had similar part failure (Wire-starter??) Thanks for all your help
  10. Jonathan Copping
    Feb 19, 2020
    4
    Sevenoaks
    Thanks - that reminds me - the dealer measuered only 6 volts!!! And I'd been using the recommended Optimate regularly to keep it charged up,,
  11. Ducatitotriumph
    Apr 25, 2019
    2,187
    Rothwell
    Did laguna offer some sort of warranty with the bike?
    If so, definitely a claim!!!
  12. Jonathan Copping
    Feb 19, 2020
    4
    Sevenoaks
    Thanks - But no extra warranty and bike over 5 years old....
  13. Callumity
    3,362
  14. Jonathan Copping
    Feb 19, 2020
    4
    Sevenoaks
    Hopefully this is the end of the saga; I've just had a new battery fitted. In November I paid out over £900 for a service and MOT incl new disc (£200) and ignition coil (£325), but the starting/battery problems continued.. EM light came on so dealer had to pick the bike up. I've used the Optimax 4 charger for nearly a year so I'm hoping the new battery will put an end to being stranded!! I've complained direct to Triumph via a survey they put out last year but heard nothing back... Thanks again for all your advice; esp re the charger (Why the dealer/Triumph themselves hadn't recommended one I'll never understand)
  15. Iron
    Iron Guest
    Jeez, another win for Hinckley and Thailand : unamused:
  16. Helmut Visor
