2018 Quick Shift / Blipper On 2014 Model?
Discussion in 'Speed Triple' started by Taff, Nov 27, 2018.
  1. Bryan3R
    Bryan3R Senior Member
    Jun 22, 2018
    230
    293
    Southend, Essex, England
    Not having any luck downloading freeware from Lonelec website
  2. Col_C
    Col_C I can't re...Member
    Aug 5, 2015
    1,435
    I admit the Tuneecu website is not the easiest to navigate around especially if you're not well up on your pc literacy.
    Go to the link below to download the Tuneecu software that needs installing on your windows laptop.
    http://www.tuneecu.com/TuneECU_En/links.html
    and download from the link I've arrowed -
    The tune library is only needed if you intend remapping for a new exhaust etc. so ignore that for now.
    There's some more installation info here -
    http://www.tuneecu.com/TuneECU_En/install1.html
    but you'll probably only need those additional drivers if you go the cable route.
    Using a bluetooth dongle it will probably run without any drivers (will just need "pairing" like any other bluetooth device)
    Hope that helps. :)
  3. Bryan3R
    Jun 22, 2018
    230
    293
    #23 Bryan3R, Nov 28, 2018
    Ive been playing and only just seen this, thanks.
    I had assumed the software wasn't available on there as its says its locked but found it a few hours ago.
    Messaged Martin at LonElec and he says the interface will work with my tablet, so ordered one, paid and downloaded app for tablet too, so ready to go when it arrives Friday.
    thanks all
  4. Colin Logue
    Colin Logue New Member
    Nov 20, 2018
    23
    Litcham, Norfolk
    I don;t think will work as your ecu will not be programed correctly
