Which front paddock stand to use with an Abba Stand?
Discussion in 'Speed Triple' started by Dougie D, Dec 14, 2016.
  1. Dougie D
    I've got an Abba stand but don't fancy their front stands,is it ok to use a front paddock stand that fits into the headstock along with my Abba stand, if so do you have any recommendations?
  2. R_1000
    R_1000 Elite Member
    Sep 2, 2016
    1,476
    700
    UK, London
  3. Dougie D
    cheers, i had thought about the front abba stand,but it looks expensive for what you get, and wasn't to keen on having to attach a strap to the swing arm every time,but the bike does look stable enough with it
  4. Col_C
    Col_C I can't re...Member
    Aug 5, 2015
    1,431
    I've got an Abba stand too and also not smitten by a strap round swing-arm. Santa's bringing me one of these.
    Got to be better than a couple of bottle jacks under the fork legs I've managed with so far. :eek:
    I do run a ratchet strap under the top yoke and over a joist in the garage roof as insurance though.:)
  5. Creaky
    Creaky Well-Known Member
    Feb 25, 2015
    122
    Nottinghamshire
    car jack for a tenner from ebay works well with a piece of timber to protect the frame
  6. Dougie D
    i've been looking at similar ones,do you know if you need an adapter to fit in the speed triple headstock? in the picture it looks as if it's not thick enough..just noticed they give you a 13mm,15mm,16.5mm,17mm and 18mm pins so i'm guesing one of them should fit(not measured it yet)
  7. R_1000
    R_1000 Elite Member
    Sep 2, 2016
    1,476
    700
    UK, London
    #7 R_1000, Dec 15, 2016
    You don't have to strap it through the swingarm. I have the - Triumph V1 Hub Spindle for Triumph Speed Triple/R (11 to 16). It's an extended Spindle (similar to the rear paddock stand which gets fed through the Hub), you just have to strap it to the extended Spindle :)
  8. Dougie D
    i have the axle nut finishers on mine, so i would have to put the strap around the swingarm
  9. R_1000
    R_1000 Elite Member
    Sep 2, 2016
    1,476
    700
    UK, London
    ^^^ That's correct.
    I have R&G axle sliders. I just take them off as it's a 5 sec job ;-). But as you said I wouldn't be comfortable strapping directly through the swingarm.
    The front stand (Col_c) put up does look good. I guess you just need the right adaptor and you are good to go :)
  10. Col_C
    Aug 5, 2015
    1,431
    I haven't checked size but I'd say as long as a pin goes in it doesn't have to be a great fit, don't imagine it can jump off too easily.
  11. Dougie D
    I'm pretty sure one of the adapters they supply with the stand should be fine
  12. Col_C
    Aug 5, 2015
    1,431
    Front stand works well with an Abba stand, only thing I had to do was put about 10mm packers under the Abba stand to gain enough clearance under the back wheel.
    SWMBO's StreetTriple (lowered suspension) was fine without any packers, it has more space under back wheel when up on stand.
  13. Dougie D
    i got one of those front stands for xmas good quality stand, I've also had to do put something under the stand, it's not a problem though as I'll only be using the stand when the bikes laid up during the winter or if I'm taking the wheel off
  14. old git
    old git Well-Known Member
    Jul 4, 2016
    194
    Aberdeenshire, Scotland
    I used the Abba stand with the attachment for raising the front wheel on my Fireblade. It was way more stable than any paddock stand I've ever used.
