Thruxton 900 Efi/neutral Light
Discussion in 'Technical Help' started by tappers, Jul 15, 2018.
  1. tappers
    tappers Well-Known Member
    Nov 30, 2015
    91
    west sussex.UK
    i gave my thruxton a good clean today, whilst starting the engine i noticed there is NO neutral light when it's in neutral,i know it's not a blown bulb as it's lit during the pre-start sequence,any idea anyone.
  2. tappers
    Nov 30, 2015
    91
    west sussex.UK
    no,it run's as normal.
  3. crispey
    Have you tried putting it in and out of gear a few times with the engine runnIng.
  4. Sprinter
    On mine the neutral light is a wire and connector just above the gear lever on the side casing.
  5. Yorkshireman
    I think the clue, and possibly the cure is in your first post. When you say you gave it a good clean what did you do? Did you take bits off to clean them and the surrounding area? The neutral light is illuminating as part of the initial sequence and as you say it's working so you have eliminated bulb failure so my guess is you have disturbed either the switch or the wiring for the neutral switch. Retrace your steps from your cleaning and double check the wire and switch, that should do it.
  6. tappers
    Nov 30, 2015
    91
    west sussex.UK
    problem sorted, it wasn't due to the cleaning after all,the wire had come off of the neutral switch on the underside of the engine i carefully applied a bit of pressure to the male tab to get a tighter fit on the connector,it was very loose when i put it back on, hence it coming adrift in the 1st place.
