Starting Problems
Discussion in 'Technical Help' started by Leonard Paton, Sep 27, 2021.
  1. Leonard Paton
    Leonard Paton New Member
    Sep 17, 2021
    KY58QD
    My triumph tiger 955i fell over while running so turned off the ignition then we got it back up. Anyway when I tried the ignition there were no ignition lights on so I thought the battery was flat so I charged it up and when I tried to put the second battery connections on the bike started to turn over and the key was turned off and so was the kill switch off. But with the ignition on and I put the second battery connections on the bike starts but when I put the key to off the engine stops but the bikes still trying to start.
  2. Leonard Paton
    Sep 17, 2021
    KY58QD
  3. MICK64
    MICK64 Active Member
    Sep 15, 2020
    89
    NEW FOREST. ENGLAND
    Good luck sorting that out. :) The complicated electrical systems today, are a right pain in the arse to deal with. I expect it has a falling over sensor somewhere, that needs re setting with a dealers computer. Probably only cost about £500 too. :)
  4. andypandy
    This question takes a bit of "getting yer ed" round it. Could it be you've got a stuck solanoid switch do you think ?
  5. Julian Wallis
    Julian Wallis THE CORNISH PIXIE
    Jun 9, 2020
    53
    when it fell over did it damage any of the kill switches or ignition wires? worth a check.
  6. capt
    capt Elite Member
    May 8, 2016
    3,051
    western Australia
    You might want to remove your post code from your profile ! Give anyone who's up to no good your location and where your bike is to within a few streets..
