Speed Triple Won’t Turn Over
Discussion in 'Triumph General Discussion' started by AlexB93, Jun 19, 2022.
  1. AlexB93
    AlexB93 New Member
    Jun 19, 2022
    2
    Alberta canada
    Hey there,
    New to the forum and new to Triumph. I have a 2014 speed triple I am trying to get going but not having much luck with it at this point.
    I have put a brand new battery in it and when I turn the key everything lights up and I can hear the fuel pump. However when I hit the ignition I get nothing at all, no solenoid click or anything.
    I was told it was the starter switch assembly but I took it apart and ran the tester on it to see if the switches were working and everything seemed to check out.
    any idea appreciated
  2. stinger
    stinger Senior Member
    Nov 28, 2017
    742
    Yarnbrook
    Might be the place to start or starter relay. I know you said it was a new battery but a low battery will cause same symptoms.
  3. Tony Rokins
    Tony Rokins Active Member
    Jun 26, 2017
    181
    Reading, U.K.
    If the starter switch checks out, the starter relay is the next port of call. Also ensure the battery is fully charged, 'cos it wont be interested in firing up otherwise, he says speaking from bitter experience:mad:
    T
  4. littleade
    259
    Worcestershire
    Do you have the bike in neutral, clutch in and sidestand up when trying to start it? I'm not up withTrumpet starting procedures as I have a ditch pump but it could be a micro switch on either the sidestand or clutch leaver. Good luck
  5. andypandy
    Check the clutch switch and the side stand switch. Just by-pass them with something like a screwdriver.
  6. Bolosun
    Bolosun Senior Member
    Aug 25, 2020
    276
    Crewe/Cheshire
    A common problem. I've had it with mine. Checked all the switches, starter motor and brand new battery. Some claim the earth from the starter motor is too blame. With mine I would have to turn the bike off and on 3 or 4 times before it would start. But the last time I noticed after the clocks sweep and the change lights sweep, if I hit the starter it wouldn't start. But if I left until the temp gauge had also finished it sweep, it would start 1st time every time. So make sure it finishes all it start up routine before trying to start it.
    And as already mentioned, make sure your new battery is fully charged.
  7. sprintdave
    1,629
    New battery may not be fully charged or not holding full charge, it happens sometimes. Check with meter.
    Other suggestions all good.
  8. TRIPLE X
    TRIPLE X Senior Member
    Sep 1, 2021
    455
    213
    Downham Market, Norfolk
    I assume the kill switch is in the run position? Also the battery terminals need to be nice and tight. It might be worth nipping them up a tad?
  9. Ducatitotriumph
    Apr 25, 2019
    2,183
    Rothwell
    As per @littleade , sounds like a clutch/stand switch!?
  10. Alan Gilbert
    Alan Gilbert Senior Member
    Nov 22, 2018
    302
    You say there is no solenoid "click".
    An obvious check is to find the low power input to the solenoid - it should be zero volts with the ignition on but starter button not pressed. Now press the starter and the input voltage to the starter solenoid should be 12V and it should activate and "click" so as to feed power to the starter motor.
    1. If no change in input voltage, fault lies in wiring from starter button or button itself. check this circuit carefully
    2. If input voltage shows 12V - starter solenoid is fubarred - replace
  11. Linx
    Linx Well-Known Member
    Mar 14, 2020
    198
    Stratford Upon Avon, UK
    Check the fuses!
  12. AlexB93
    AlexB93 New Member
    Jun 19, 2022
    2
    Alberta canada
    Thanks everyone! I messed with the gear shift and for some reason that seemed to get it sorted out for now.
  13. TRIPLE X
    Sep 1, 2021
    455
    213
    So it was in gear with the stand down. That's why it would not start, even with the clutch pulled in.
  14. sprintdave
    1,629
    Doh. Lol, hey we've all been there, well they have, I haven't.
