Speed Triple 2012r Remapping 2 Options ?? Which One??
Discussion in 'Newbies Hangout' started by Jai, Sep 28, 2018.
  1. Jai
    Jai New Member
    Sep 27, 2018
    10
    woking
    Hi I am slightly confused on choice of mapping to download for my speed triple 2012 r ::
    But confused as to which one to chose::
    Be great to get some knowledge :)
    Running very rough... basically dies at the lights and everywhere else i stop.. revs hunt sometimes up to 2 & back down to 1. But currently revs are so so low at half then cuts out..... no fun at lights.... got to keep the revs up....:::
    TWO OPTIONS BELOW FROM TUNEECU::
    Speed Triple 1050 R model / From VIN # 499001 to VIN # 735437 , ABS model / Keihin ECU :::
    20521Map.hex OEM md5checksum ABS Use with Arrow slip-on. Fuel up to E25. Minimum 95 RON (89 RON/MON) fuel.
    20522Map.hex OEM md5checksum ABS Use with Arrow slip-on. Fuel up to E25. Minimum 91 RON (87 RON/MON) fuel.
  2. dilligaf
    Hi Jai and welcome
    Sorry I can’t help with your question but I’m sure one of the inmates will be along soon to point you in the right direction :)
  3. Sprinter
    Why do you think its the map causing the problem. Could be air getting in at the throttle body rubbers.
  4. capt
    capt Elite Member
    May 8, 2016
    3,052
    western Australia
    Several ways to test for leaks in manifolds, WD 40 or Aero start or talcum powder. WD 40 and Aero start will cause engine revs to rise or fall immediately after light spray, talcum powder will be sucked into the gap leaving a dark area where the leak is .
    Hope that helps
  5. Rspete
    Rspete Elite Member
    Jun 17, 2018
    1,794
    743
    Durham
    The lads are correct it doesn't sound anything to do with the mapping.... maybe connect tuneecu to bike and do a diagnostic check to see if any faults pop up if none show, do what capt suggests check hoses for splits etc.
  6. David Cooper
    Hello and welcome to the forum Jai
  7. Jai
    Jai New Member
    Sep 27, 2018
    10
    woking
    Hee Hee thanks again :)
    Bit of a mystery as to why then the tuneecu will not see my bike :(
    Get the red light flashing then error: ECU is not responding: Check cable connection: Turn ignition off and on.”
    1. deleted drivers and reloaded
    2. already tested on lovely daytona and worked a treat much older bike and been heavily modified
    3. my speed triple has already connected to an obd2 diagnostic code reader and works
    frustrating as heck my speedy is constantly hunting on the throttle and then conking out at a stop
  8. dilligaf
    Hi Jai
    Try asking your question in the speed triple section of this forum :)
    Not everyone comes into the newbies hangout :confused:
    And I know that there’s lots of owners in there and quite a bit of knowledge about tune ECU :p
  9. Jai
    Jai New Member
    Sep 27, 2018
    10
    woking
    hello thank you
    me wee bike ... had to buy new ecu brains will see how it pans oout ....
  10. Jai
    Jai New Member
    Sep 27, 2018
    10
    woking
    helooo like that pic... thanks you
    still awaiting to tuneecu out me bike ... got the new ecu brains.. second hand of course.. the weekend will be either celebration or swamps of tears
  11. Jai
    Jai New Member
    Sep 27, 2018
    10
    woking
    still awaiting to tuneecu out me bike ... got the new ecu brains.. second hand of course.... with be one of two scenarios ... get to ride my remapped bike running best ever since i have had it... or.... tears.,. and taking bike to triumph... tears are over the expense...lol
  12. Jai
    Jai New Member
    Sep 27, 2018
    10
    woking
  13. Bad Billy
    Hi & Welcome, hope you get it sorted.
  14. Red Thunder
    Red Thunder Crème de la Crème
    Dec 2, 2014
    2,035
    High Wycombe
    Definitely try the WD40 around the air intakes under the air box
    Make sure the airbox is secured correctly
    Safe to presume there is no air blockage in the air box or the filter is nice n clean
    Spark plugs are new/gaps correct
    SAI has been done to reset the throttle position at tick over (when bike is stone cold, turn on ignition without touching throttle, and leave it until fan kicks in, this should reset the throttle sensor/tick over position thingy)
    If tick over is so bad the above can't be done then as suggested TunECU would help diagnose issue with throttle balancing and error codes, just have to get it to connect
    Are you using a mobile device or laptop for TuneECU - try the other is so...may help
    What is the battery condition, if low voltage, may cause low engine speed problems (stretching here, but worth checking)
  15. Jai
    Jai New Member
    Sep 27, 2018
    10
    woking
    hi thanks for your response ... we pretty much done everything except remapping... this weekend ... will let you know how i go ...
  16. Jai
    Jai New Member
    Sep 27, 2018
    10
    woking
    Hi thanks agian this weekend fingers x'd gots the new ecu brain so should go smooth if not ... ........./:{
  17. Wessa
    Hi and welcome.....
    Wessa
  18. Tiglet
    Hello Jai and welcome to the forum :)
  19. Jai
    Jai New Member
    Sep 27, 2018
    10
    woking
    hello thanks again :)
  20. Jai
    Jai New Member
    Sep 27, 2018
    10
    woking
    cheers great to gleen loads of knowledge :)
