Nudger Needs Advice
Discussion in 'Technical Help' started by dilligaf, Aug 23, 2018.
  1. Red Thunder
    Red Thunder Crème de la Crème
    Dec 2, 2014
    2,037
    High Wycombe
    Word from Triumph M40 is that the new ECU can be adjusted and remapped, BUT if you try and change it again, even to put the original map back in, it would brick the ECU
    This is so no-one can put in their own map, bugger the engine up then put the original map back and claim it wasn't their fault
    I am fully prepared to be corrected but this is my understanding as per a Triumph dealer
  2. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    I am surprised that nobody has created a compact stand alone ECU for modern bikes, there are plenty of car orientated ECUs and piggybacks but they are going to be too big for a bike.
  3. dilligaf
    Like I said I went and had another look :)and I don’t need to chop/cut anything but will need to make pipe extensions :p.....easy :)
    My concerns are with the ECU and will it adapt :confused:
  4. Tiglet
    All this talk about piggyback is this what you mean :eek:
  5. steve lovatt
    It's Dilligaf - are you seriously expecting him not to touch the throttle? :joy::joy::joy:
  6. TEZ 217
    Well feck me where was your eyes when you looked first time, extensions are easy bought from flea bay (Stainless) rather than pinching round steel tube from work ;) as for ECU follow Stripplemonts advice run without touching throttle.
    At the end of the day its your choice and risk :skull::cold_sweat: all of this shit is guesswork. :cool:
  7. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    All a std ECU will do if the battery has been disconnected for a bit depending on how clever, is relearn idle control and once being driven is relearn short term fuel and timing trims... unless its using wide-band lambdas and using live feedback tables, i used to tune and remap car ECUs and piggybacks.
  8. StrippleMont
    StrippleMont Senior Member
    Nov 5, 2016
    349
    220
    Round your way!
    Don't sound bad stock
    Your bike, do what you like
    "Dilligafit!"
    :pEnjoy!
  9. Sprinter
    I dont think there is a risk swapping end cans, it will be good or a bit crap, and your ecu will reset.
    I cant see it will break the bike.( I dont fing know).
    I imagine you could put them on, see if you like them and swap them back if you dont like them, with no ill effect.
    I think end cans are physical thing, and only if your fussy would you need to remap.
    I swapped my exhaust for a delkivic 2000 miles ago and have no problems.
    I decided not to remap, cos the gains were only above 100 mph and so didnt effect my riding.
    If I remove the CAT, air box sensors, and exhaust sensor, I need to plug in TuneEC, only because, the ECU would keep telling me via the engine management light, that the sensors are missing, so I would need to tick the boxes in the display so the ECU didnt look for these.
    https://www.triumphrat.net/ecm-and-...and-questions-pertaining-to-installation.html
    https://www.thetriumphforum.com/threads/nudger-needs-advice.15424/page-2 Skip to 20 mins in to see laptop ECU and whats involved.
    I wouldnt be to worried about having ago.
    This is for my bike you dont remap you just switch off the two sensors,
    I dont know how this effects your model.
  10. steve lovatt
  11. ElectrAbigail
    ElectrAbigail Someone to reMember
    Aug 18, 2018
    512
  12. steve lovatt
    Not only cruel but spelt incorrectly! :D:D
  13. Help me Obi Wan...
    Help me Obi Wan... Well-Known Member
    Right direction might be this way.
    • WTF WTF x 1
  14. StrippleMont
    Nov 5, 2016
    349
    220
    Round your way!
    Standards are going down the pan on this forum:sob:
  15. ElectrAbigail
    Aug 18, 2018
    512
    Mind your tongue Kenobi!
  16. crispey
    Ok then “ propper “
    Is that better
