Newbie Advice For Pictures And Avatars
Discussion in 'Newbies Hangout' started by Helmut Visor, Apr 16, 2020.
  1. Helmut Visor
    Hi Jamski :cool: if you start your own thread in the Newbie section you will get a lot more views rather than posting in the how to load pictures thread ;)
  2. Havit
    Hi Jamski, Welcome to the forum. Where to start.... I would guess its a fuel issue. Has fuel been left in the tank? Remove and replace with fresh. If The tank has rust it may need cleaning. Cider Viniger Is good i beleve. I have fitted an inline filter .Dont try and start theses bikes unless the battry is good or theres a chance of the sprag clutch getting stuck (common fault on the 900s) Carb clean may be needed as they get can get gunked up if fuel is left in them for long periods. Keep a lookout for the the smell of fuel or leakage from the air filter as if the floats get stuck it will bleed into the airbox and or the Engine oil. Good luck.
  3. Jamski
    Jamski New Member
    Aug 23, 2025
    15
    Penmarc'h France
    Hi Havit, and thanks for the info/advice.
    I'm hoping to get it fixed, seems like a big job and I have my fingers crossed that there are no issues with the sprag.
  4. Bikerman
    Also pull the clutch lever in before you hit the starter button.
  5. Havit
    You would know if the sprag was stuck the starter wouldnt disengage. I am not a mechanic, but took on a project Thunderbird 900 and stripped it down. The hardest part of removing the carbs is getting the airbox out of the way . Just disconnect the throttle cable and choke cables, lossen the jubilee clips on the rubbers both sides of the carbs , push the airbox back as far as you can and rock the carbs loose and slide them out.
  6. Bikerman
    And prepare for the air to turn blue. Done my airbox a few years ago. What idiot designed it like that. Should be shot. :joy::joy:
  7. Ray2020
    Ray2020 New Member
    Aug 31, 2025
    4
    North East
    IMG_1860.jpeg Loving it!!!
  8. Peter_IND
    Peter_IND New Member
  9. danielmacdiesel916
    danielmacdiesel916 New Member
    Sep 10, 2025
    Wilton
    Just got my new project home, 2000 Triumph Daytona 955i with 30k miles. Engine Rumbles Nicely. First ride on it coming soon, probably just after the sun comes up.
  10. TexasGator
    TexasGator New Member
    Nov 24, 2025
    12
    Dallas TX USA
  11. Thescousesqurriel
    Thescousesqurriel New Member
    Thanks for this Forum, and Hello I'm stef, I'll be asking questions soon
  12. GA Forester
    GA Forester Well-Known Member
    Dec 9, 2025
    12
    53
    USA
    Hello from North Carolina. I ride a 2023 Triumph Speedmaster. Got it second hand couple months ago and was loving it.
    And then ran into issues and will be asking for help and suggestions here.
    Cheers all !
  13. GA Forester
    Dec 9, 2025
    12
    53
    USA
    Cheers all !
  14. Helmut Visor
    Howdy GA Forester :cool: You have piggy backed onto an info thread at the moment but if you start your own thread in the Newbie section you will get a much better response ;)
  15. Nigel Walker
    Nigel Walker New Member
    Jan 4, 2026
    7
    West Yorkshire
    Hi all, just introducing
  16. Nigel Walker
    Jan 4, 2026
    7
    West Yorkshire
    Sorry phone slipped, as I was typing, my name is Nigel Walker (Nig) from West Yorkshire.
    Got 2 lovely Triumphs, one a Trophy 3 900 1992, and the other a T595 Daytona 955 1997.
    I can't bare to part with them, so much torque, absolutely love the feeling when they pull.
    My Dad originally had the Trophy from 1994, and I inherited it when he stopped driving some 3 yrs ago.
    The Daytona is mine from 2009, absolutely love it, and still pulls like a train up to 10,200 rpm in all gears.
    Kept them both standard ish.
    Well thank you for the accept and keep the rubber side down
  17. Wessa
    Hi Nigel, you should start a new thread to introduce yourselves, rather than this information thread.
    Don’t worry you are not the first or likely the last to do this. :)
