Help With Bad Sounds
Discussion in 'Technical Help' started by Steven S., Nov 19, 2018.
  1. joe mc donald
    On all my Bonneville's I still use the split link. Put on correctly I think is good enough. I can see if its a sports tourer or speed machine. But then people get out a big hammer to put that soft link on. If you don't have the proper link spreader tool then get it done by you local dealer. Again with seizes links if you or my method is to turn the wheel slowly watch the front sprocket and that link will never sit right. Just my two pence.
    Ride Free
    Joe
  2. MrOrange
    I do agree, but we all need to learn, and often best way is just getting stuck in. Do your research, make sure you have a clue and give it a go. It's a good way to learn. YouTube is brilliant, I learned how to install a kitchen from Youtube !!! Or even better, get a pal that is competent on bikes, and ask him to supervise to start with.
    If really desperate, come on here and ask !!! :p:laughing::laughing::laughing:
    Doing stuff on the bike is just part of being a biker, and not a Euan/Charlie-twat-suit-wearing knob, and just taking the bike to a dealer for simple little jobs like tensioning a chain.
    • Agree Agree x 7
  3. Bad Billy
    Agreed MrO, part of the bike owning experience is the fettling the bike yourself, when a bike is new then the warranty etc demands main dealer but with an older bike I do it myself.
    However peoples skill set vary wildly, for some adjusting the chain is difficult for others a complete ground up engine rebuild is easy (@darkman for instance), I am somewhere in the middle, can't take (4 stroke) engines to bits, but happy changing a clutch, brakes, chain & sprockets & doing the general servicing bits myself.
  4. joe mc donald
    MrOrange.
    Of course you are right and even more so with the research. Right tools. If in doubt ask. Its how we all learnt. And its great to hear and see people out there doing the jobs a dealer would fleece you to do.
    Ride Free
  5. Steven S.
    Steven S. New Member
    Nov 19, 2018
    4
    Maryland
    So have an update. I put a new chain on, make sure it was not too tight and had the wheel spinning in first gear while the bike was still up on its center stand.
    I still hear the same sound as before but it sounds like its coming from around the rear axle area. Maybe a bearing or something else... Also I have always torqued my rear axle nut to the required 63 ft/lb, but it always feels way too tight and my rear wheel will stop spinning freely. I'm now suspect that my torque wrench itself might not be calibrated. Its not a bad one, a snapon brand that I got from my Grandfather, but it's also not the newest since he had it long before me. Just something else I need to verify to remove any doubts I have.
    Either way long story short is I can't figure out exactly what the problem is now after doing what I feel I can to the bike so my next step is a trip to the shop...
  6. joe mc donald
    Steven S.
    Sometimes it is best saves the brain cells. If yo have the wheel out try putting you finger in and turning the bearing you will feel if it is rough in places. And its not that hard a job to replace them. And do make sure you got all the spacers in the right places the wheel is straight.
    Ride Safe
  7. Oldyam
    Oldyam Grumpy Old Git
    May 14, 2017
    612
    ireland
    If the rear wheel tightens when you torque up the axle nut then there is some problem with the assembly of the rear axle, either there are parts missing or assembled in the incorrect order.
    Try this link to the parts breakdown for the assembly order.
    http://www.worldoftriumph.com/trium...ck_01=&block_02=100065022-3-2&block_03=610810
    Maybe it will help you see something that was incorrectly assembled or missing, possibly before you looked at it .............
  8. tcbandituk
    2,902
    Reading
    I'd take the wheel out and check inside the sprocket/wheel hub.
    It's difficult to tell but it almost sounds like there's something rattling around in the wheel hub.....
  9. Steven S.
    Nov 19, 2018
    4
    Maryland
    #29 Steven S., Nov 26, 2018
    So I have had the wheel off in the past but its a pain trying to hold the tire up to get the axle back through on my own and don't feel like going though that headache again at this point.
    The last time the wheel was put back on was at the dealer themselves so I would hope they had everything on correctly but honestly who knows.
    I'm sure there are some fancy ways people have found to make it easier but at this point I just feel like cutting my losses and taking it to the shop without having to guess what the problem/fix is.
  10. Richard Neale
    Richard Neale Active Member
    Apr 20, 2018
    156
    Northwich
    It's a nuisance for you ! Maybe it is something the shop did. I think you would be best taking it to the shop if possible and getting them to let you watch them inspect it . Unless of course there are any mechanically experienced people on here who are local and can go through it with you. I wish you the best of luck with getting it sorted !
  11. Sprinter
    Crushed a bearing perhaps.
