help removal of 2012 speed triple air box
Discussion in 'Technical Help' started by dan1050triple, Jun 30, 2016.
  1. dan1050triple
    dan1050triple Member
    wirral
    help please just trying to remove the air box on 2012 1050 speed striple i have removed all the pipes plugs and bolts but it dont seem to want to come off is there somothing am missing here please help
    #1
  2. dan1050triple
    wirral
    its done now
    #2
  3. Carter
    Carter Member
    Brough
    Guess I came along about four hours to late lol
    #3
  4. dan1050triple
    wirral
    yes lol all done and put back on now, way to many pipes and plugs on that air box jesus over kill
    #4
  5. Wasp
    Wasp Well-Known Member
    Burnley NWUK
    Any chance you could share the knowledge please Dan?
    Im about to try to fit the carbon fibre frame infills...
    Cheers pal
    Bob
    #5
  6. dan1050triple
    wirral
    thats why i removed mine to fit the in fills. remove the seat first remove tank held in my 3 bolts 2 at the front one long one at the rear, there are 2 breather pipes and 2 pugs on the under side of the tank just unplug the lot and the fuel line. put the tank to one side.
    remove battery
    on the air box there are 2 large bolts were you romoved the battery can see once the battery is out
    and 2 more at the back of the air box with the seat meets the tank so 4 in total. remove them there are a few pipe and plug to undo on the air box but you will see them all when its in fornt of you. once you have unpulled and pipes you need to give the box a good yank give it a wiggle and pull back to the seat and up its a bit stiff but will go, once thats out you can unbolt the infills and fit your own, when you put the box back give the rubber inlets of the air box as little spray of wd40 or the likes. so when you put it back the rubber inlets of the air box go over the inlets on the throttle bodys you will see this and will make sense when you see it. if you get stuff mail me for number you can fone me and will talk you through it if you get stuck
    #6
  7. Wasp
    Burnley NWUK
    Top man Dan, thanks a lot.
    Hopefully get a chance tomorrow but if not it'll be next weekend.
    Cheers pal
    #7
  8. dan1050triple
    wirral
    ok inbox me if you get stuck or want a talk through before you start it
    #8
  9. Wasp
    Burnley NWUK
    Will do, cheers Dan.
    #9
  10. Wasp
    Burnley NWUK
    Dan,
    I had a crack at it today, and ur not wrong about it being overkill!!!
    Anyway it's done, so thanks for the post describing the way, very helpful-and the tip about lubing up the rubbers that fit over the throttle bodies on reassembly.
    Learned summat else today... Whenever this bike gets sold, it's sold with these still fitted!!!:mad::D
    Atb
    Bob
    #10
  11. dan1050triple
    wirral
    lot of messing but never mind hay done now
    #11
  12. anthony gothard
    anthony gothard Well-Known Member
    lancashire uk
    Did mine today, with help from your post. 3 bloody hours.....job done...Or so i thought..... checked everything out afterwards and NO HORN. could hear the relay clicking, scratched my head, put a new relay on. still nothing.
    Nothing for it, tank off, air box off again.......ooooooooooops, one live wire had dropped under the air box and i never saw it....Could have kicked myself..
    A full day to put the infils on.HA
    #12
  13. Jody
    Jody Active Member
    Nuneaton
    You not got a workshop manual ? Cough ;D
    #13
  14. anthony gothard
    lancashire uk
    Nope. It's a new bike, didn't think I'd need one. I'll have a look for one later
    #14
  15. Wasp
    Burnley NWUK
    I Said you weren't done spending Tony...;)
    Bob
    #15
