Gear Indicator
Discussion in 'Speed Triple' started by Andrew Richardson, Aug 14, 2017.
  1. Andrew Richardson
    Morpeth
    Hi, just looking through threads on gear indicator for a 63 plate with ABS, so does it mean there is no way that I can fit a gear indicator???????:confounded::pensive:
    #1
  2. Col_C
    Col_C I can't re...Member
    You can,........ but with ABS it's a bit of a pain.
    For the non abs bikes you can just plug in to the OBD socket (with the DS model) and job done, but apparently the pin-outs are different for abs models and there is no speed signal on the obd. This means you have to use the X-type and also fit a speed pick-up (GPX-WSS) which is available from GIPro.
    There are some photos and details of fitting here (you'll need Google Translate :)).
    Personally, looked a bit too much hassle and untidy for me, .....I only occasionally go for 7th gear.
    I believe the speedo gets its data from the abs sensors (via the ecu I guess), I'm sure if HealTech put in the effort they could tap in to the correct wire and use that, but I guess the market isn't big enough to make the effort......so I'll pass.
    #2
  3. R_1000
    R_1000 Elite Member
    UK, London
    #3
