Fuel Soaked Air Filter On Bonneville
Discussion in 'Technical Help' started by Neil1970, Jan 11, 2020.
  1. Neil1970
    Neil1970 Member
    Oct 25, 2019
    30
    East Sussex
    Hi guys. I’ve just stripped the carbs on my 2001 Bonneville, cleaned the jets and replaced the float valve. Started her up and lots of sooty emissions!
    I checked the air filter and it’s soaked in petrol. I dried out the air box and started her up and she runs fine...BUT..when left standing, switched off, the air box starts filling with fuel again..am I just looking at a stuck float valve or crud on the seating ?
    Thanks in advance
    Neil
  2. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    Answered your own question there.:)
  3. joe mc donald
    Floats need to be set up as well.
    Regards
  4. Neil1970
    Neil1970 Member
    Oct 25, 2019
    30
    East Sussex
    How’d you set them up Joe?
  5. joe mc donald
    Neil1970
    Make sure its not just a stuck needle first. If not you have a little tongue on the float that operates the needle shut of plunger. Just adjust the tongue till it shuts of at the desired point without overflowing the float bowl.
    Regards
    Joe
  6. Neil1970
    Neil1970 Member
    Oct 25, 2019
    30
    East Sussex
    Thanks Joe, really appreciate your help. That’s tomorrow sorted then
  7. joe mc donald
    Neil1970
    If you have the carbs of it is an easy job. I just get a refill tube and a remote filler then just loosely hold the float bowls and let them fill then check. Remember when you take them of the level will drop a little in the bowl as the float raises it when on. This you will know if the fuel overflows the bowl edges as you meet them up. I am not explaining this as good as I know it in my head. Hop you can work it out.
    Regards
  8. Neil1970
    Neil1970 Member
    Oct 25, 2019
    30
    East Sussex
    You’re
  9. Callumity
    3,358
    #9 Callumity, Jan 11, 2020
    It sounds like the needle is not seated properly or being held open. The fuel rises so the floats are too high or obstructed if there is no shut off.
    The top of the floats should ride 16-18 mm above the rim of the float bowl. You adjust by bending the tab onto which the needle valve is hooked.
  10. joe mc donald
    Callumity
    Thankyou for helping me out with this one. I was having difficulty getting it out of my head and putting it into words.
    Regards
  11. Neil1970
    Neil1970 Member
    Oct 25, 2019
    30
    East Sussex
    Thanks Callumity, I’ll give that a whirl and see how it goes
  12. capt
    capt Elite Member
    May 8, 2016
    3,051
    western Australia
    Also , is there a vacuum hose from one intake manifold to the fuel tap ? Not sure of the Bonneville's , but earlier carbureted T300's (trident etc) they had vacuum switched fuel taps ? Has yours ? It could be the faulty part , they last 6 to 10 years.
  13. Neil1970
    Neil1970 Member
    Oct 25, 2019
    30
    East Sussex
  14. Neil1970
    Neil1970 Member
    Oct 25, 2019
    30
    East Sussex
    Hi Capt,
    I don’t believe it does but I’ll gladly stand corrected. I’m hopefully having enough time myself to check the float height and seat for debris tomorrow..
