Was asked by a chap I rode with the other day. Said you have no daylight head light on. He's right, no light. Is it a change of bulbs or fuse, anyone had this issue?
Don’t think it’s a bulb, it’s an led isn’t it? First thing is check all fuses and other lights , it’s likely that the DRL will be fused with something else. Then check the connection in the headlamp and the wiring around the headstock, weren’t some bikes recalled due to a problem in that area?
Thanks, I'll check the wiring at the headstock as I have been moving some about for the new handlebars.
Good news is that the connector had come out, bad news is that the retaining clip is broken off. I've heat shrunk some heat shrink onto it so it has something to grip.
