Bonneville Starter Problem
Discussion in 'Technical Help' started by SteveMiller, Jul 22, 2017.
  1. SteveMiller
    SteveMiller New Member
    OH
    Hello everyone, I hope someone can help. I have a 2007 Bonneville which died last week, wouldn't start so I put in a new battery, connections all tight. Still won't start, all fuses are good, starter relay clicks when the neg is unhooked, lights work, kickstand up, clutch in all the simple things check out. The only thing I get when I push the starter button is a buzzing sound, like an old time door buzzer, from what sounds like the right side under the battery.
    Any ideas?
    Thanks
    #1
  2. thebiglad
    Sounds like the starter relay has failed.
    #2
  3. Ken walburn
    Ken walburn Noble Member
  4. Ken walburn
    Agreed, almost certainly the starter motor relay
    #4
  5. MickEng
    MickEng Noble Member
    West Yorkshire
    Have you tried bump starting it ?
    I agree with biglad on the relay, but it would be good to know if it starts by other means.
    Starter motor may be stuck ?
    #5
  6. Callumity
    It is a very cheap generic component. I would swap it out rather than break sweat!
    #6
  7. SteveMiller
    OH
    Tried a new relay today, nothing but buzzing coming from it. Any other things to check?
    Thanks
    #7
  8. MickEng
    West Yorkshire
    #8
  9. Ken walburn
  10. Ken walburn
    Ok, are you sure that the buzzing is coming from the starter relay? Tip - plastic handled screwdriver, metal end on relay, plastic end to ear, unless you have a stethoscope, press starter switch, trace source of buzzing by moving driver to each component whilst attempting to crank. Once certain starter relay is buzzing further checks wil be required. Will cover those if required. Might be an idea to bump start as suggested just to ensure starter circuit at fault & not an additional issue.
    #10
  11. Ken walburn
    #11
  12. Samuel F
    Samuel F Well-Known Member
    Glasgow
    I'm sure it needs a little love. Just ask with love. (Private joke, I don't mean that).
    I know as much about mechanics as a Blind Rabbit knows about quantum physics...
    #12
  13. Sprinter
    Does the pump prime?
    #13
  14. dilligaf
    You're right :heart_eyes: love conquers all :heart:
    Even a B P O S:p:kissing_heart:
    #14
