Bonneville Fuel Pump Torque
Discussion in 'Technical Help' started by TonyG, Jun 6, 2019.
  1. TonyG
    TonyG Noble Member
    Dec 1, 2016
    825
    Bucks
    Hi,
    I've decided to splash out on a little torque wrench. Now that I'll be using it I'm hoping someone can confirm the fuel pump mounting bolts torque. My Haynes manual says 5nm, but I've seen it listed at 9nm online. 5nm seems correct to me, it's just setting a thick rubber seal. Can anyone confirm?
    Thanks
  2. TonyG
    TonyG Noble Member
    Dec 1, 2016
    825
    Bucks
    Thanks, I'll stick with 5nm as you suggest.
  3. capt
    capt Elite Member
    May 8, 2016
    3,051
    western Australia
    Just do up FT by hand with the appropriate spanner size.
    It's always worked for me.
    Capt
  4. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    I'm afraid the concept of using a torque wrench on small bolts/nuts is alien to me i would just tweak it up until it felt right.
  5. TonyG
    TonyG Noble Member
    Dec 1, 2016
    825
    Bucks
    I have always just done things up at this small torque by hand as well, it's just that there are 12 bolts securing a pretty vital rubber seal and I just wanted to get them even. If I had the tank back from the painters I would have just got on with it, but am still waiting which led to me ruminating, which led to me buying the torque wrench. It's quite interesting as 5nm has even less feel to it than I imagined.
    Cheers
