Boneville T100 Front Line On, "switch" Mode Not. Does Not Start.
Discussion in 'Technical Help' started by Caro E, Jan 17, 2021.
  1. Caro E
    Caro E New Member
    Jan 17, 2021
    I have Boneville t100 (2013). My mistake of not using it for a bit, but had the battery connected and charged.
    I turn the key and the front light turns on bright. Keep turning the key to "switch" mode where you start the motorcycle, but nothing happens, the panel does not turn on, I cannot even try "turning it on". No sounds made no clicks.
    What could that be? thanks
  2. Ducatitotriumph
    Apr 25, 2019
    2,183
    Rothwell
    check fuses and actual battery voltage.
    If it's the original, its knackered.
    Voltage may seem ok, but it's probably not.
  3. dilligaf
    9 times out of 10 it’s the battery :confused:
    But check fuses and connections especially the battery leads at both ends :)
  4. Pegscraper
    Pegscraper Elite Member
    Jun 12, 2020
    3,427
    Check the battery voltage when under load, You can get 12v+ from a "fully charged" knackered battery but it drops several volts under load.
  5. Caro E
    Caro E New Member
    Jan 17, 2021
    Thanks so much, I will try to find where the fuses are at. And will check the battery again.
  6. Caro E
    Caro E New Member
    Jan 17, 2021
    Yes, thanks. That is why I actually removed the battery to have it on a bettery tender. It seemed to be fine.
    The battery turns on the full light, but does not go further than that. Maybe I need a new battery.
    Thanks
  7. Caro E
    Caro E New Member
    Jan 17, 2021
    I have not checked it when the light is on yet. That will be my next step.
    Thanks so much. I am pretty new to this so I need to find ways to fix this. Thanks.
