About Metal / Cnc Brake Reserviors
Discussion in 'Speed Triple' started by Alom, Apr 30, 2022.
  1. Alom
    Alom Member
    Apr 2, 2022
    30
    guys, any suggestion on the front and rear brake reservoirs? I don't like those original plastic reservoirs............thanks for any help in advance.
  2. Alom
    Alom Member
    Apr 2, 2022
    30
    cheers, mate. I'm checking with the seller for the rear one. but the front one does not fit my bike.....so sad. it's very cool out looking. yep, the Rizoma should be ok. but I still want to get the Triumph parts prioritized.
  3. Ducatitotriumph
    Apr 25, 2019
    2,187
    Rothwell
    I did this to the rear brake ms.
    Not everyone’s cup of tea but took 15 mins and £20!
  4. Alom
    Alom Member
    Apr 2, 2022
    30
    :Dgood idea. but, hold on, may I know the type of your SC exhaust? and where did you get the carbon fiber heel guard?:heart_eyes:
  5. Ducatitotriumph
    Apr 25, 2019
    2,187
    Rothwell
    #6 Ducatitotriumph, Apr 30, 2022
    https://shop.sc-project.com/en-US/3520_T22A-T38C-CR-T-Muffler.htm
    heel guards were £25 second hand. I’d do a search on eBay as they are readily available brand new for about £100
    Any excuse for a pic!!! :):)
  6. Alom
    Alom Member
    Apr 2, 2022
    30
  7. Arno triple
    Arno triple Senior Member
    Aug 26, 2018
    613
    • Thanks Thanks x 2
  8. Alom
    Alom Member
    Apr 2, 2022
    30
  9. Arno triple
    Aug 26, 2018
    613
    WoW! That’s quite a distance indeed! I may be coming over in 2025, if you still want them then …
  10. Alom
    Alom Member
    Apr 2, 2022
    30
    all good, mate. I am checking the front one for 1200RS. it looks like can be installed on my bike.
  11. Alom
    Alom Member
    Apr 2, 2022
    30
    yep. the front one should be compatible with my bike. totally the same mount on it.
  12. DanielB
    DanielB Noble Member
    Jan 13, 2019
    887
    393
    Abingdon, Oxfordshire
    Hi, am curious...what "detail" does one need to know if replacing reservoirs? Or are they all functionally the same, except for how they may actually attach? Or do different bikes have different valves or flow or something?
    Or is it a case that as long as you can get it on and attached, it "works"?
  13. TRIPLE X
    TRIPLE X Senior Member
    Sep 1, 2021
    699
    Norfolk
    It's just a reservoir and as long as it is attached above the brake lever/master cylinder so there is gravity feed it should be fine. Just the brackets for attachment seem to vary from bike to bike. The front reservoir is usually bigger than the rear to suit larger/twin calipers up front.
  14. DanielB
    Jan 13, 2019
    887
    393
    Thank you!
  15. Alom
    Alom Member
    Apr 2, 2022
    30
