955i Engine Coatings
Discussion in 'Builds & Projects' started by Stephen Marshall, Feb 21, 2018.
  1. Stephen Marshall
    Stephen Marshall New Member
    Feb 20, 2018
    5
    Lambeth
    About to prep my tiger 955i engine for a partial repaint. After some advice on the correct process. Looking a e-tech heat resistant enamel. Is an etch primer advised with this or not.:idea:
  2. darkman
    Acid etch primer should be used on bare alloy.
  3. Stephen Marshall
    Feb 20, 2018
    5
    Lambeth
    Thanks for your reply I will go with that. Are there any you would recommend? A brush on one would be preferable
  4. darkman
    Never seen or used brush on, i use u pol acid etch and you can get it in aerosol. you only need to spray it on lightly as one coat does it.
  5. Stephen Marshall
    Feb 20, 2018
    5
    Lambeth
    Thanks for that. Looks like thats the way i will go.
  6. darkman
    Just make sure its all super clean and prep with a scotch pad n panel wipe.
  7. Stephen Marshall
    Feb 20, 2018
    5
    Lambeth
    Thanks to all who replied to my post. I am going with u-pol 8 acid etch primer suggested with an e-tech high temp enamel coating. This project is going started when the weather warms up a bit. Will up date when complete. :cool:
