2022 Street Triple Rs Battery Maintenance - Help!
Discussion in 'Technical Help' started by Rich Martin, Nov 23, 2022.
  1. xorbe
    xorbe Noble Member
    Jan 27, 2021
    278
    363
    CA, USA
    20A! I specifically use the smallest 750mA battery tender because the 1.5A model was boiling my small motorcycle batteries. In fact I wanted to avoid "peak charging" altogether, so I also added a digital wall timer that turns on for 75 seconds once an hour. That works out to 30 minutes/day without peak voltage charging. Often it goes straight to green after blinking red for 5 seconds.
    BTW if you have a lithium battery, I don't know if there is a solar powered option, that's more tricky.
  2. Baza
    Baza Elite Member
    Jul 25, 2020
    3,871
    Amazing Grace
    I think you mean 20 Watts. o_O My Optimate 4 only kicks out 1 amp. My Optimate 3 which lasted 20 years 24/7 was less.
  3. alfie
    374
    213
    Bath, Zumerset
    #23 alfie, Nov 30, 2022
    Bugger, you are correct. I will go and sit in the corner. Note to self, don’t use the tablet when it is past my bedtime.
