2012 Speed Triple Coolant
Discussion in 'Technical Help' started by Richard H, Apr 23, 2013.
  1. Richard H
    Richard H Noble Member
    Oct 26, 2012
    1,134
    Checked the coolant level on my bike after a long weekend ride out and its right on the low mark on the bottle. No problem I thought just top it up but have looked and can not see how to fill it up without lifting the tank. Am I missing something or is that what you have to do?
  2. Screwball
    Screwball Active Member
    Mar 21, 2013
    1,018
    36
    Don't know.... But in the manual it does say...
    Always chek the level with the engine cold.......
    To access expansion tank, raise and support the fuel tank... Remove the cap from the expansion tank...etc etc... You know the rest..
  3. Richard H
    Oct 26, 2012
    1,134
    Perhaps I should have looked at the manual :rolleyes: But From what I could see there was no alternative, crap design though, you can get at the coolant on the Street Trip just by lifting the seat
  4. brybrem
    brybrem Senior Member
    Mar 8, 2013
    1,435
    North Wales
    And on the 07 SIIIs.
  5. Screwball
    Mar 21, 2013
    1,018
    36
    It's only coz I had my manual local at the time...
  6. JimDiesel
    JimDiesel Member
    Feb 27, 2013
    450
    16
    Nottingham
    Isn't the filler cap under the left side pod on top of the rad?????
  7. Richard H
    Oct 26, 2012
    1,134
    Yes Jim but it says you top it up via the expansion tank, and you can not use water! So trip to Pidcocks for some HD4X Hybrid OAT coolant :frown: Will see if they will do it for me FOC .......
  8. Richard H
    Oct 26, 2012
    1,134
    Called in at Pidcocks Triumph and they said they do not fill the tank past the low mark from new as when they get hot it pushes the excess fluid out the overflow which exits near the back tyre:eek:
    As a double check I looked at their demo Speed Triple and it looked slightly below the low mark so I guess he is not B/Sing me
  9. Screwball
    Mar 21, 2013
    1,018
    36
    Try use distilled water normally rather than tap water...
    Or just throw in some antifreeze...
  10. JimDiesel
    JimDiesel Member
    Feb 27, 2013
    450
    16
    Nottingham
    Fek I've never checked mine.... Where do you look???
  11. Richard H
    Oct 26, 2012
    1,134
    It isn't that obvious, go to the chain drive side of the bike, locate the cover of the the front drive sprocket of the chain, look up about 50mm and you will see a black plastic cover. Behind this cover is the bottle, you can see it looking from the front of the bike looking back.
