2011 Speedy - What Battery Voltage Question
Discussion in 'Speed Triple' started by GuySal, Apr 27, 2023.
  1. GuySal
    GuySal Member
    Sep 15, 2021
    49
    Derbyshire, UK
    Hi guys
    My 2011 speedy needed a full battery charge after 3 months on an optimate - I took the optimate off expecting immediate start .... a couple of cranks and then nothing!
    I'm at 12.6v unloaded at the mo. Anyone out there let me know what the unloaded / ignition on / running voltage should be pls?
    I don't mind getting a new battery but just wanted an idea of what my bike should be running at voltage
    Thanks
  2. Eldon
    Eldon Crème de la Crème
    Leave the meter connected and crank it over.
    Anything less than 11.0 volts under load is time for a new one.
  3. Bolosun
    Bolosun Noble Member
    Aug 25, 2020
    526
    343
    Crewe/Cheshire
    When you hit the starter button, what reading do you get on the battery? It should not go below 10v.
  4. andypandy
    As above plus consider the age of the battery. Triumph supplied batteries don't usually last five years. In fact any battery that old must be suspect.
  5. Linx
    Linx Well-Known Member
    Mar 14, 2020
    198
    Stratford Upon Avon, UK
    In my experience Optimates and alike kill batteries if left on for a long time. Better to take off the bike and just give it a charge occasionally over winter.
  6. GuySal
    GuySal Member
    Sep 15, 2021
    49
    Derbyshire, UK
    Hi all
    Looks all good - keeps at 12.6 unloaded and well over 11cranked. Will keep an eye on it over next week or so. Cheers for the help all
  7. GuySal
    GuySal Member
    Sep 15, 2021
    49
    Derbyshire, UK
    Come to same conclusion on the optimate. Next winter I'll take off the battery then fully charge it in spring
  8. Bolosun
    Aug 25, 2020
    526
    343
    Crewe/Cheshire
    I have my optimate on a timer. It's set to switch on for a few hours one day a week.
  9. GuySal
    GuySal Member
    Sep 15, 2021
    49
    Derbyshire, UK
    That's a great tip thanks. I'll do the same
  10. Baza
    Baza Elite Member
    Jul 25, 2020
    4,861
    Amazing Grace
    Apologies but I cannot agree with you guys about Optimates being battery killers.
    In 2010 the OE battery on my Ducati became unfit for future use. It had been on an Optimate since I bought the bike new in 2001, so an acceptable lifespan.
    My replacement battery, after some relocation of components under the tank, allowed me to install a physically larger battery. I also chose to use one of the Odyssey AGM batteries which are built to military specs. This battery, like the OE one before, is connected 24/7 to an Optimate (the first one lasted 19 years).
    The Odyssey battery is still providing sterling service, as is my Optimate 4. So not only has it lasted 12 ½ years so far, it’s larger size allowed me to go from 11 to 18 amp/hours.
    I said my first Optimate lasted 19 years. As it turns out it was only one of the LEDs that ceased to function. One of my sons now uses it to service one of his bikes.
    Finally, I saw mention above of running the Optimate off of a timeswitch. I now have two bikes that are on the road but only one Optimate. I have devised a cunning plan to automatically share the Optimate between the two bikes using two plugin timers and a double pole, double throw mains relay. Total cost should be under £20, less than half the price of the cheapest Optimate. If anyone is interested PM me an email address and I will happily provide the details.
