2004 Bonneville T100 Starting Issues
Discussion in 'Bonneville' started by Rodngonzo, May 19, 2024.
  1. Rodngonzo
    Rodngonzo New Member
    May 19, 2024
    reno
    Help!!! Went to fire bike up after the winter and nothing...... Battery is good.. I replaced the starter solenoid just in case and still doesnt work. I am getting power across the starter button as verified with a meter and if i put alligator clip on negative terminal of battery and attach another lead from positive post to small clip on top of starter solenoid she fires right up!! The bike is in neutral and the kickstand is up... What else can it be at this point? I also checked all fuses.....I just wanna ride....Bike is a 2004 t-100 carbed...
  2. Samsgrandad
    Samsgrandad Senior Member
    Dec 15, 2019
    724
    Somerset
    Have you checked the side stand switch, and the kill switch?
  3. joe mc donald
    @Rodngonzo
    Welcome to the Family. Yes as stated by @Samsgrandad check all those switches Clutch side stand. And look for good clean connections and fully functioning battery and switchgear and chaffed wires around the headstock and switch. Keep us informed on the progress. Joe
  4. Rodngonzo
    May 19, 2024
    reno
    I noticed that the headlight wasn't shutting off when pushing start button and after muddling through the schematics I discovered that a bad headlight cutout relay could be the issue as that relay is what sends power to coil on starter solenoid..11 dollars later and she fired right up!! Rewarding to figure it out myself...thanks all for the suggestions!!!
  5. Rodngonzo
    May 19, 2024
    reno
    And now today..went to start bike and nothing..bought another relay and nothing..I can here the relay clicking so that isn't the problem as the new one allows the same click...I had already replaced the solenoid but maybe that's it again? What the hell?
  6. Rodngonzo
    May 19, 2024
    reno
    I drove it all day but stopped for a sec and left key on...thought that was problem but jumping didn't solve it..ended up shorting across solenoid with a screwdriver but I can't keep doing that..
