2003 triple speed speedo not working?
Discussion in 'Technical Help' started by tony955i, Apr 14, 2016.
  1. tony955i
    tony955i Member
    Nov 17, 2015
    ludworth durham
    Evening all I have a problem with the speedo not working, is this an easy fix or do I have to remove the front wheel and replace the sensor?
  2. sprintdave
    May 25, 2014
    1,709
    did it work before or has it never worked? have you removed the front wheel, i know some bikes can be a bitch to get the sensor working after wheel removal
  3. t552
    t552 Senior Member
    Nov 17, 2014
    418
    Bristol UK
    have you had a new tyre before it stopped working? that is the usual cause, then they break the magnet in the speedo drive. Replacements are available from a guy in Germany
  4. thebiglad
    I take that a 2003 Speed Triple's speedo is driven by the front wheel and not the gearbox?
  5. tony955i
    tony955i Member
    Nov 17, 2015
    ludworth durham
    Yes it's front wheel driven, not sure wether to remove and clean it and check magnets or just purchase a new one have found the part number Pfkl 1201343. Not cheep. Lol
  6. sprintdave
    May 25, 2014
    1,709
