Which Rectifier/regulator 2005 Speed Triple
Discussion in 'Technical Help' started by Vulpes, Jan 16, 2021.
  1. Vulpes
    #1 Vulpes, Jan 16, 2021
    Last year my stator was replaced, but not the rectifier/regulator. I now think that part is suspect, and want to replace it.
    I've read about MOSFET replacements, more specifically bits written by @D'Ecosse, who appears to be very knowledgeable, but I do not have the skills to splice or solder new connections.
    Does anybody know if there's a straight swap available?
  2. Smilinjack
    Smilinjack Guest
  3. t552
    t552 Senior Member
    Nov 17, 2014
    418
    Bristol UK
    Helps to know what bike.
  4. Vulpes
    Fixed that mate...
  5. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
  6. Red Thunder
    Red Thunder Crème de la Crème
    Dec 2, 2014
    2,037
    High Wycombe
    2nd for Electreworld
    I have bought a regulator from them and it controls the voltage nicely
    Bypasses the main loom and connect dir to battery for better efficiency
  7. Vulpes
    Is that easy to install? I'm not very skillled in the electrickery department..
  8. Sprinter
    Soldering or joining is easy. You could simply do it yourself in an hour honest.
