Triumph America 865 Carb Model 2007
Discussion in 'Technical Help' started by Antcar, Jan 30, 2026.
  1. Antcar
    Antcar New Member
    Jan 30, 2026
    Norwich
    Hi all my 2007 triumph america 865 carb model cuts out when put in gear if I bridge sidestand connector works fine so must be dodgy sidestand switch but when checked with multimeter is OK bought new one still the same checked clutch switch and neutral switch neutral light goes out when in gear checked wiring for damage have read about diodes but have no idea where they are but confused as to why it is OK when I bridge the side stand connector block any ideas cheers
  2. Robbi18
    Robbi18 Member
    Jun 15, 2025
    29
    United States
    The diode block is likely fried. It's a small black box under the seat near the main harness. Your switches test good, but the diode fails and tells the bike the stand is down even when it's up. Bypassing the connector proves it. Find that diode block, unplug it, and bridge the correct two wires in its connector. If it runs then, you need a new diode pack. Common Triumph gremlin.
  3. Antcar
    Antcar New Member
    Jan 30, 2026
    Norwich
    Hi thanks any idea where I can get a diode pack in the uk foud some I america most out of stock or want £100 spend one I have seen is sumitomo 3 pin m double diode 6098-0129
  4. joe mc donald
    @Antcar Welcome to the family. Nice bike do tap the upload a file button and let us all see it.
  5. Antcar
    Antcar New Member
    Jan 30, 2026
    Norwich
    Here is the bike that's driving me mad
  6. joe mc donald
    @Antcar Your picture didn't materialize. Try tapping the upload a file button and try again.
  7. Antcar
    Antcar New Member
    Jan 30, 2026
    Norwich
  8. Antcar
    Antcar New Member
    Jan 30, 2026
    Norwich
    For some reason won't upload
  9. joe mc donald
    Possible to big for the download you may have to resize.
