I'm removing the protective bungs from my Daytona. Unfortunately I don't have the original bolts but World of Triumph tell me I need 2 different bolts - PFKL1214761 BOLT,TX,M12X1.25X64 and PFKL1214076 BOLT,HHF,M12X1.25X70. As they are around £10-11 each from WoT I wondered if anybody has sourced them elsewhere??
if you search out M12 x 1.25 on Google there are plenty of options. Looks like you need 65mm and 70mm bolts Torx standard but you could use socket cap head hex etc.
https://www.ebay.co.uk/itm/M12-12mm...hash=item2a39b41e23:m:mDjIJ5Muw7bpIyNgmUjPcWw Probably find a lot cheaper if you persevere.
Exactly, and 40p cheaper than the packet of 100 you can get from Poundland with the added bonus of not having to store 99 surplus ones.
So if you want two bolts you’ll probably end up paying about £15 for a poly bag with Triumph printed on it
It doesn’t matter if they fit or not it’s the fact you’ve got a poly bag with Triumph printed on it counts
I didn’t realise that you’d get two poly bags,,,,,that makes a huge difference. Well worth spending the extra ££’s
I'd throw in the bubble wrap packet and cardboard box they're shipped in too. Not Triumph branded mind you.
You’ve convinced me Rich but only if there’s Triumph on the box Then I can put the box on the coffee table in my lounge and look at it all goggle eyed
Thought you would like an update Turns out the bolts are used from the inside of the frame to mount the RG sliders - so bought nyloc nuts, good to go. But no chance of branded bag n box
