Tiger 900 Gt Pro Check Engine Light
Discussion in 'Technical Help' started by Gregg, May 3, 2021.
Tags:
  1. Gregg
    Gregg New Member
    May 3, 2021
    Shasta County, CA
    Hi I just got a new Tiger 900 GT Pro and it threw a check engine light. I pulled the code and it is a P1577 code. I think its related to a brake sensor and my brake lights are stuck on. I've called two Triumph dealers to confirm what the code is and none have called me back and they are both about 200 miles away. Does anyone know if this problem is a brake switch issue or can the code be caused by a short? The cruise was shutting off randomly before the engine light came on which makes me think it's possibly a short.
  2. Ducatitotriumph
    Apr 25, 2019
    2,187
    Rothwell
    Hi there!
    Luckily, its under warranty so call them to get it sorted!
    Hopefully, the below will help you for the future gregg
    https://www.triumphrat.net/threads/triumph-dtc-codes.789537/
    https://www.tiger800.co.uk/index.php?topic=19790.0
    Ok, it's not showing the exact one put good for reference.
    Definitely call the dealer and make a ride of it!?
  3. Gregg
    Gregg New Member
    May 3, 2021
    Shasta County, CA
    Thanks for the reply and the info! Bike is still under warranty just gotta get the dealers to communicate with me lol.
