THUNDERBIRD (1995) 900 bATTERY UPGRADE BATTTERY OPTIONS
Discussion in 'Technical Help' started by Bowtie, Mar 20, 2017.
  1. Bowtie
    Bowtie New Member
    Mar 15, 2017
    CM112EG
    Now that I have suffered the dreaded and expensive sprag failure, can anyone suggest a battery upgrade option.
    (Extras fitted include:- daytime running lights, boom stereo, air horn, Garmin satnav, auxiliary night lights and alarm/immobiliser).
    Thanks
    Paul
  2. crispey
    Sorry!
  3. Bowtie
    Bowtie New Member
    Mar 15, 2017
    CM112EG
    I guess that means I need to upgrade the fuse box (again) !
  4. stevethegoolie
    stevethegoolie Elite Member
    Oct 16, 2014
    2,455
    East Riding of Yorkshire
    Got a bright yellow:eek::cool: Motobatt in my '95 Trident. Been in there for around 21 months or so and it has held its charge beautifully in that time despite irregular useage, and it spins the engine over with great gusto and enthusiasm making starting easy. Approx 190cca (cold cranking amps) available at the push of a button!:cool:
    Just sayin' like!:rolleyes:
    I believe Yuasa do an equivalent version (similar cca) which some may prefer.
  5. Bowtie
    Bowtie New Member
    Mar 15, 2017
    CM112EG
  6. t552
    t552 Senior Member
    Nov 17, 2014
    417
    Bristol UK
    Yes. I would go for the Yuasa YTX14AHL-BS. 210 CCA. I have known some motobatt's to split open.
  7. stevethegoolie
    Oct 16, 2014
    2,455
    You just have to remember to wear sunglasses when you take the seat off on a bright/sunny day!:eek::cool:
  8. bogg
    bogg Senior Member
    Feb 21, 2016
    west sussex
    Go for the lithium,ebay £105 with the charger
  9. sprintdave
    1,624
    Lol I love this thread, yuasa, lithium, motbatt et al.
    I have a motobatt on my Sprint, been perfect all the time I had it on, others have said the same, some have said to buy yuasa, others pay a ridiculous price for lithium at double the cost
    You pays the money and takes the choice, good luck
  10. Petrol
    Petrol Well-Known Member
    Sep 18, 2016
    178
    North Wilts.
    Motobatt is the best. But get it from a reputable dealer as there are some fakes out there. I'm useing a later ecu and that makes sure the engine is turning over at least 200 rpm before making the ignition live and protecting the sprag.
  11. Havit
    If you keep the battery well charged or use your bike regularly you wont have any issues.
  12. Oldyam
    Oldyam Grumpy Old Git
    May 14, 2017
    610
    ireland
    Have you upgraded the charging system to cope with the extra demands of all the extra's you have fitted ? ( upgrade wire sizes & shorter cable run to battery )
    If the charging system cant keep up you will just run the battery flat, no matter how big a battery you fit
  13. Havit
    I run my sat nav and charge my phone and still have a good charge.
  14. Oldyam
    May 14, 2017
    610
    ireland
    Yes but the OP is running a little more than that ..........Post Quoted Below ...........
    ***Now that I have suffered the dreaded and expensive sprag failure, can anyone suggest a battery upgrade option.
    Thanks
    Paul ***
