Thruxton R Running Hot And Smells Of Petrol
Discussion in 'Newbies Hangout' started by Dave Rowsell, Jul 10, 2019.
  1. Dave Rowsell
    Dave Rowsell New Member
    Jul 10, 2019
    East Sussex
    Hi all, I have just bought a 2016 Thruxton r from a main dealer, but have noticed a smell of petrol in my garage and the engine seams to run very hot quite quickly, is this to be expected or have I bought a pup?
  2. Dave Rowsell
    Jul 10, 2019
    East Sussex
    Hi Ron, no lights on, probably just being paranoid, nothing on the floor, just a strong smell of petrol when left in the garage, seems to have died down a bit now, never had a triumph before , hence asking the questions
  3. Sprinter
    Age? Is it carbs or injection?
  4. Dave Rowsell
    Jul 10, 2019
    East Sussex
    Three years old, only has 5000 miles on the clock
  5. crispey
    Cmon sprinter you’re not that old and decrepid the fact he calls it a 2016 thruxton r gives it away.!
    How many times have you filled the tank? Have you just spilt fuel? I have a feeling there was a recall for thruxton for the fuel line or something, have a look here then check here
  6. Sprinter
    Sounds like nothing to worry about.How long was it running before the fan kicked in?
    It may be the previous owner altered the map for the fan to kick in early, for commuting.
    If theres no petrol visible I wouldnt worry yet.
    Ride it, thats the best test.
  7. Dave Rowsell
    Jul 10, 2019
    East Sussex
    Just taken delivery today from the dealer, I suppose they might have spilt some petrol when they filled it up today, I will keep an eye on it, do they naturally run hot very quickly? I would like to think that the main dealer has had it back for the recall, as it was originally supplied new from the same dealer
  8. crispey
    There’s a few thruxton r owners on here so hopefully, when they drag themselves out the pub, they’ll give some feedback
  9. Retired Phil
    Jun 22, 2017
    212
    San Rafael
    Fuel smell is not right and dangerous. Clean everything up. Go for a ride. Now take a look around under the tank near the Quick Disconnect that goes to the fuel line into the fuel rail. Then all the stuff by the throttle bodies. Leaking fuel will make a stain the you can see.
    After i got my TTR, a small O ring on the fuel rail was leaking. No biggie. Dealer just replaced it and no more leak.
    Next, what do you mean Running Hot?
  10. David Cooper
    Hello and welcome to the forum Dave.
  11. Vulpes
  12. Helmut Visor
    Hi Dave, and welcome in :cool::cool:
  13. dilligaf
    If you fill the tank up with diesel and it starts smelling of diesel then you will know you’ve got a leak :p
    (Don’t fill it with diesel :()
  14. Flashp
    Flashp Noble Member
    Dec 6, 2017
    595
    343
    Hants
    Get it back to the dealer and let them resolve it. You'll have a warranty so use it.
  15. Tiglet
    Hello Dave and welcome to the forum :)
    If you have a problem get back to the dealer.
  16. Ken walburn
    Ken walburn Noble Member
    Jun 28, 2017
    889
    If I run my ‘R’ low on fuel & park it up in the garage, the next day the garage stinks of fuel. This is completely normal for this bike so don’t worry. Full tank, no’smell, almost empty tank, fuel smell. Done 11K now with no issues, so chill out :)
  17. Retired Phil
    Jun 22, 2017
    212
    San Rafael
    ^ no. Fuel smell in any circumstance is Not normal.
  18. Ken walburn
    Jun 28, 2017
    889
    Sorry I do not agree, my fuel tank & cap are vented, With a full tank there is little vapour, therefore little venting. Under certain conditions (temperature related) & with low fuel levels there is more vapour in the tank than fuel, if the weather gets hotter, the vapour has to vent. Particularly with the type of tank fitted to the Thruxton R which effectively has two fuel cells
  19. Dartplayer
    Hi Dave and welcome to the forum :cool: How are you determining the the bike is running hot? Stationery most modern bikes get to temp quickly as they want air movement. Fan comes on if sitting at lights or left for more than a couple of mins
  20. Wishbone
    Wishbone First Class Member
    Nov 4, 2018
    865
    643
    Essex UK
    Its a Triumph its meant to run hot!!
    and they always stink of petrol especially in a garage.
    Ony kidding get it straight back to the dealer for the stink of petrol issue:p
