Sprint Tank Upgrade/revamp???
Discussion in 'Sprint & Trophy' started by Duckadiledundee, Jan 1, 2020.
  1. Tigcraft
    Tigcraft Not Well Known Member
    Eh?? Blimey wtf?? How? Wife Shot it with an arrow or something??
  2. Yorkshireman
    Yeah, she was aiming at him and he, er, “duck”ed :worried:
  3. Duckadiledundee
    Duckadiledundee Peasant First Class
    1,927
    High Peak
    Ahhh... now I understand and I may have seen that on other tanks....
  4. Duckadiledundee
    1,927
    High Peak
    If only you knew what I have to put up with...
    Or it could be what she as to put up with...:p
  5. Duckadiledundee
    1,927
    High Peak
    I was advised that nub at the front of the tank was solid so I decided to angle grind a few millimetres off...
    Guess what...it ain't solid on one side but is on the other which makes me think a bit of a bubble formed there during the injection moulding process...
    Don't take that as gospel though....
  6. Duckadiledundee
    1,927
    High Peak
    I was inspired to use the kitchen sink by @Sprinter to clean out my fuel tank...
    It's worked out very well....
    Obviously the wife ain't here at the moment...
  7. Duckadiledundee
    1,927
    High Peak
    Tank repair kit wont be here now until Tuesday so I'm stuck for things to do...
  8. Duckadiledundee
    1,927
    High Peak
    What can I use to seal/bung these cavities up when I'm applying/swishing the sealant around inside the tank....
  9. Duckadiledundee
    1,927
    High Peak
    A balloon...what if I inflated a balloon inside the three cavities...
  10. capt
    capt Noble Member
    May 8, 2016
    1,778
    450
    western Australia
    Cut cardboard or plastic template to fit it's only coming out as soon as you have swished the chemicals around
  11. Duckadiledundee
    1,927
    High Peak
    I thought it had to be sealed up really well so it doesn't leak out ...
  12. Don the Don
    213
    And should the balloon burst you are covered in the shit, the template idea is a good way to go as you swill it about then remove the templates simple.
  13. Duckadiledundee
    1,927
    High Peak
    What if I used extra strength condoms ( first time for everything I suppose )...
    I tried a plastic bag and duct tape to cover the cavities when I was swilling it out just to clean it all out with little success :confused:
  14. Yorkshireman
    A firm in Yorkshire has a large supply of condoms duck, they bought them from a company in Northamptonshire,apparently they were marked as extra large but are due to be sent back cos they are too small. I could have a word if you like. :D
  15. Duckadiledundee
    1,927
    High Peak
    I only need three possibly four...
    1 fuel cap
    2 fuel sender
    3 huge fuel plate
    4 possibly see if I can still put one over my head :p
  16. Duckadiledundee
    1,927
    High Peak
    About to apply some quiksteel epoxy in the hole i put in my tank..
    You get two tubes off Amazon for a tenner and the label comes out the tube and gives you instructions on how to use and you can reseal what you don't use ( bonus )..I forget who recommended it on here but thanks for the information its appreciated...
    Wish I could apply it from inside the tank but I shall do the best I can and with two helpers pointing out where the hole is I think it will be ok...:p
  17. Duckadiledundee
    1,927
    High Peak
    I don't claim to be a sculptor....
    I guess I never lost my play doh skills I acquired as a kid...
  18. Duckadiledundee
    1,927
    High Peak
    HOORAY...tank sealant kit just turned up...
    Getting there fellow triumph people...
    Need a tub to mix it in but the wife wasn't happy last time I used her Tupperware stuff to measure out my fork oil...:scream:
  19. Don the Don
    213
    Its all coming together, like the helpers.
