T595 engine cuuting out
Discussion in 'Technical Help' started by Kyohoon, Nov 21, 2016.
  1. Kyohoon
    Kyohoon New Member
    Nov 21, 2016
    Sheffield
    help/ advice required,
    I own a 1998 T595 Daytona, it has recently started cutting out after around 3 to 4 miles, it appears as though the fuel is cutting out. The engine turns over but will not start up again until after it has rested for around 40 minutes ish. I have changed the fuel pump, filter and pressure regulator along with the electrical relay, and the problem is still there. Does anyone know what the problem could be.
    Cheers Andy.
  2. sprintdave
    May 25, 2014
    1,679
    Could be the fuel pipe blocked or twisted and not allowing fuel through. Also could be an air lock,? Try it with the petrol cap undone. You say after about 40 mins, on my bike I would say check the crank position sensor but sorry I don't know about yours. They tend to fail when hot and after cooling down they work ok for a bit.
    I am sure the more knowledgeable guys will be along soon
  3. Kyohoon
    Kyohoon New Member
    Nov 21, 2016
    Sheffield
    Thank you I will check the sensor
  4. Kyohoon
    Kyohoon New Member
    Nov 21, 2016
    Sheffield
  5. thebiglad
    Hi Kyophoon (fascinated by the name btw!) I would be checking the petrol tank vent, as it sounds like there might be a problem with air flow (which should be entering the tank as fuel is used up) being blocked.
  6. crispey
    Have you tried running it with the fuel cap off/open?
  7. t552
    t552 Senior Member
    Nov 17, 2014
    417
    Bristol UK
    could be crank sensor
