Is there a replacement fuel cap that has the retro look without the key lock? There must be a retro replacement fuel cap. Does anyone know of anywhere where you can get any from?
Well you can still get one. A company called Monotone do a billet screw on fuel cap. You can check a video out on you tube. If you go onto YouTube and search 'views from the man cave'. He has a video fitting one to his Street Twin and as the Street Twin and T120 have the same fuel cap it'll fit both machines.
Thanks for that info, interesting videos from 'views from the man cave', however this is the type of cap I'm looking for: http://www.dimecitycycles.com/vinta...ph-bonneville-thruxton-scrambler-48-2677.html I'll have to find out if it fits the modern T120...
I would think it probably will fit the T120. If a fuel cap for the previous model Bonneville fit the Street Twin they'll more than likely fit the T120.
I ordered the cap from Dime City Cycles; http://www.dimecitycycles.com/vinta...ph-bonneville-thruxton-scrambler-48-2677.html Looks really good and exactly what I was after
I'm glad someone else thinks the locking cap on the T120 is a pain/unnecessary! This cap looks really good Andy, a bit thicker than the 'older' Bonnie cap? Also I see you bought the right colour bike!! How much did they charge you p+p etc?
I had to pay $22.50 for p&p etc then £14 for import duty and admin fee! But it looks a lot better than the original
Hi Andy probably asking obvious but that is the exact cap you got and it does fit the new2016 Bonnies ? It's just I asked the people in America and this is the reply I would recommend checking the inside of your filler neck to see if there is a vent tube sticking up from the base. If so, this cap may not fit. As for ordering, just place an order through the site and we'll be able to send wherever you indicate on the order.
I know this is a an old conversation and I’m actually shocked nobody else has voiced similar displeasure with the locking fuel caps on their Bonnevilles. It appears that the locking portion of the cap is fitted with a snap ring and could easily be replaced with a non-locking cover if anybody offered such. The search is on...
You do know that you can leave the fuel cap unlocked so you just screw it on and off. Just unlock it and remove the key
https://www.motone.co.uk/motorcycle...25/custom-fuel-gas-cap-billet-aluminium-p1552 If you check the description it seems the screw in filler caps are fairly interchangeable across the whole Bonneville range. FITS ALL YEARS BONNEVILLE THRUXTON, AMERICA, T100, SPEEDMASTER, SE, SCRAMBLER, BOBBER, STREET TWIN, STREET CUP, STREET SCRAMBLER, T120 : 2001-2018 Present - Fits both CARB and EFI bikes. FITS ALL YEARS HARLEY DAVIDSON WITH SCREW DOWN CAP 1981-2018 PRESENT SPORTSTER, 48, IRON ETC
I have the Motone fuel cap on my bike. I like it a lot. One thing you should know, though. At certain angles of the sun, it reflects directly into your eyes, causing a bit of concern if you're not expecting it.
Tried to remove the key from the cap and the only way I can is with it locked back onto the tank. What am I missing here? The stock cap doesn’t look bad. That’s not the issue. Having to pull the key from the ignition switch to gas and go is too fiddling and unnecessary. Anybody else able to unlock their cap and leave it unlocked?
