Speedo Problem
Discussion in 'Newbies Hangout' started by Mike Scard, Jun 4, 2025.
  1. Mike Scard
    Mike Scard New Member
    Hi all .. newbie here , I’m riding a 2004 rocket since new , I’m looking for help here from people who’ve experienced or know how to solve a problem with my speedo , on restarting after winter storage my clocks are only doing a sweep after starting the bike and not at ignition, then I noticed my tacho meter was resetting to zero each time I started up , and then yesterday my speedo just stopped working but stays lit up , I would appreciate any help in where to start with this problem.. many thanks Mike
    #1
  2. Eldon
    Eldon Crème de la Crème
    Rats and mice o_O
    :joy:
    Check battery voltage first then earth's for corrosion ;)
    #2
  3. Mike Scard
    I’ve just put a new battery on and had a service , I know this is a stupid question, but where do I find the earth points to check? .. I’m going to lift the tank later and look at all the joining blocks ect , I’ve looked at the fuses earlier and all seem ok .. many thanks for your help !
    #3
  4. Boothman
    Boothman Elite Member
    Wigan
    #4
  5. Mike Scard
    Thank you !!
    #5
  6. Helmut Visor
    Hi Mike :cool:
    #6
  7. Mike Scard
  8. Mike Scard
    Hi all
    #8
  9. Mrs Visor
    Mrs Visor Crème de la Crème
    Hi and welcome, hope the problem gets sorted!
    #9
  10. Mike Scard
    Thank you so much !!
    #10
  11. Wessa
    Hi and welcome…
    #11
  12. joe mc donald
    @Mike Scard Welcome to the family. Hope you get it sorted soon. when you do hit the upload a file button bottom right corner and show it of. Also a picture of the clocks and faults sometimes helps jog peoples minds.
    #12
  13. Mike Scard
    Thank you for your reply and many thanks for the welcome !!
    #13
  14. Mike Scard
    Thank you !!
    #14
  15. Eldon
    A new battery proves nothing, have you a voltmeter?
    12.7volts plus should be the answer. Any less it needs charging.
    Easiest way to identify the earth's is to start at the battery. Follow the negative wire to the frame etc and check carefully for corrosion and tightness. Any doubt disconnect and clean then refit.
    #15
  16. Mike Scard
    Thanks for your reply , yes I’ve checked the battery and it shows a full charge, but now with your advice i can start checking the earth connections .. many thanks
    #16
  17. Regit nogara
    Regit nogara Active Member
    North, North Wales
    Hi Mike, welcome to the forum. Best of luck with your problem.
    Tony
    #17
  18. Mike Scard
    I would like to thank you all so much for your useful help !! .. I took on board every thing that was advised and this morning done what eldon had told me , plus I took all of the relays out and sprayed with wd40 as well as earth terminals , let it run for half hour , no change so decided to ride to the next town to see if a Honda garage had an OBD scanner.. on the journey my speedo came back , and when I stopped to go in the Honda garage I tried once more to start her up and yesss the light had gone out !!! So one happy chappie here I can continue on my journey .. once again thank you all so much !! It gave me hope … Mike
    #18
  19. Bikerman
    Greetings from Lincolnshire.
    #19
  20. Regit nogara
    North, North Wales
    Hi Mike, this is what forums are all about.
    Happy riding:grinning: Tony
    #20
