Hi I have a gray 2019 Speed Twin which I seldom use when dark. Recently I used the bike in the evening I discovered when I was in full bean and change to dipped the lights went out. I assumed this was the halogen so replaced it. This made no difference and it become apparent it was the day light running bulb that was not working. When I switch on day light running its the dipped beam that is actually on. So my dip beam/day light running switch appears to be inverted? I can't find a circuit diagram anywhere to confirm this, the only info I can find is that the full beam/dipped bean come off the same fuse and the day light running bulb does not appear to have one. Can anyone confirm the wiring here?
