Speed Twin - Changing Mode By Itself?
Discussion in 'Bonneville' started by manxmouse, Sep 23, 2024.
  1. manxmouse
    manxmouse Well-Known Member
    Peterborough
    Has anyone notice an unexpected change in the mode setting on your Speed Twin (2019-2021)? I have noticed a few times recently that it’s in Road when I left it in Rain or Sport when it was left in Road.
    It is possible i have bumped the mode button when parking up. I have been watching for this. I have seen the mode indicator flashing in Road when shutting off the ignition and then starting it back up and watching it change to Sport.
    But I am also curious if something is getting zapped during shutdown or cranking. I have had one recent instance where the clock/trip memory reset during cranking. Previously that was the related to a tired battery. Current battery is less than 1 year old, appears in good health but not carried out any deep battery testing.
    #1
  2. Eldon
    Eldon Crème de la Crème
    It does sound like a voltage supply drop out.
    Check around the headstock area for wiring strains and chafing.
    Breaking and remaking jackplugs, with a spray of water displacer, GT85 or similar, wouldn't go amiss and may identify a dodgy pin.
    The nearside/ left-side of the headstock was a favourite on the gen 1. I removed the left bracket and machined off the sharp corner of the headlight bracket.
    Wiring damage
    Note original shape of headlight bracket (satin black, bottom left of picture).
    Note new shape of headlight bracket
    This seemed to resolve it nicely so I removed it again and had it re-powdercoated.
    #2
  3. manxmouse
    Peterborough
    Thanks. I’ll check the harness and connectors in that area.
    #3
  4. Eldon
    Speed Twin is now a confusing term thanks to Triumph changing the names.
    Just for clarity, the above pics are from a 2019 StreetTwin 900 (now called Speed Twin):rolleyes:
    Hopefully this will give you some idea's to check, irrespective of specific model ;)
    #4
  5. Jimbo1950
    Jimbo1950 Well-Known Member
    Scotland
    I had a similar problem with my 2019 Speed twin 1200, when it would reset the trips and clock to zero if I had to crank it over more than once. Although the battery seemed OK when I tested it, a new battery cured the fault and it has never re-occurred since.
    #5
  6. Helmut Visor
    Mrs Visor has just had an issue with her Sreet Triple. It changed mode by itself and then wouldn't change at all for a while then be able to change once.....you get the picture. Having done a load of research it would seem water ingress is the issue (certainly with hers) and is having to get a new switch assembly on Friday : unamused:
    You would think that Triumph would sort this as it's guaranteed to see water at some point in its lifetime :rolleyes:
    #6
