Speed triple 94R 2015
Discussion in 'Speed Triple' started by gary1966, Jul 2, 2016.
  1. gary1966
    gary1966 Active Member
    suffolk
    loving it but not loving the running in.
    What's the best quick shift to fit to the 2015?
    Anyone fitted a gear indicator??
    #1
  2. Wasp
    Wasp Well-Known Member
    Burnley NWUK
    Get on the motorway, and get 'em walloped off.
    No idea about the quickshifter mate, but i do know Anthony Gothard has fitted a gear indicator, and done a damn good job of it too. PM him, i'm sure he'd be happy to help if he can.
    ATB
    Bob
    #2
  3. gary1966
    suffolk
    Not a lover of sitting in 6th on a motorway, I have run a few bikes in over the years and like to use the rev range and up and down the gear box.
    #3
  4. anthony gothard
    anthony gothard Well-Known Member
    lancashire uk
    #4
  5. Rocker
    Rocker Elite Member
    Suffolk
    I've never run a new bike in just the tyres!
    Don't bother;) they don't run the demonstrator in:D
    #5
  6. gary1966
    suffolk
    I am the same I go steady for the first tank of fuel then I just up it through the Rev range, don't go near the red line until after the oil has been dropped, after that it's full beans.
    #6
  7. gary1966
    suffolk
    #7
  8. Carter
    Carter Member
    Brough
    Fitted a gear indicator to my 2012 the first day I got it. Easy enough now looking back, was more of a pain learning to take the bike apart.
    #8
  9. anthony gothard
    lancashire uk
    yes pretty straight forwards, took me ages but that was trying to find which wire to connect to on
    the crank sensor, splicing and connecting.
    with a sensor mounted against rear wheel abs ring.
    For our bike it should come with the appropriate wiring loom.
    i would say approx an hour start to finish. but i have my display set into the dash which takes a bit more time.
    the only downfall i have with it is, for it to recognise the gear you are in, you need to be moving, not a problem until you come in hot to traffic lights and stop quickly. just have to use the nuteral light on dash and work it out from there
    #9
  10. Carter
    Carter Member
    Brough
    #10
  11. anthony gothard
    lancashire uk
    Hmmmm, interesting...let us all know if you get one.
    #11
  12. Dickie
    Dickie Active Member
    Tadcaster, North Yorks
    I'm interested in the HM Superlite for my 2015 Speed Triple R - £224 +£10 for the connecting rod on the HM website.
    Any warranty issue likely in the even of gearbox or engine issues?
    Looks easy to install - see youtube vid.
    #12
  13. Carter
    Carter Member
    Brough
    If anything goes... take it off then get it looked at lol. There's nowt to fitting.... power, earth, sensor wire and coil pack harness. Job done
    #13
