Slight/slow Oil Leak
Discussion in 'Triumph General Discussion' started by learningtofly, Oct 20, 2025.
  1. learningtofly
    2,454
    I've noticed recently that I have a very slight/slow oil leak, with the oil collecting on the casing immediately below the site glass. The oil level doesn't appear to be affected in any tangible way, and it just needs a wipe when I start/get back from a ride. There's not enough oil escaping to leave a deposit on the floor of the garage, even when it's been standing for a week.
    I'm no mechanic and will book it in at Triumph for a repair. Any ideas what it might be, though?
  2. crispey
    You say it's collecting below the sight glass, is there any evidence of oil above the sight glass? if not it could be the sight glass seal weeping. Try cleaning that area and drying it then put a small amount of talcum powder or equivalent around the edge of the sight glass and see if there is any leak from there.
  3. learningtofly
    2,454
    Thanks, and will do. If anything, it seems to be coming from the above left, if that helps.
  4. crispey
    Remind me what bike you have? Any photos of the suspect area?
  5. learningtofly
    2,454
    It's a T120, and sadly not.
  6. crispey
    Two other places to look at
    1, where the cables come out of the alternator crankcase cover just above and in front of the sight glass. The rubber grommets can weep, that'll be above right
    2 take the sprocket cover off and have a good clean up behind there, sometimes crud and excess chain lube builds up and leaks out. that'll be above-ish left
  7. learningtofly
    2,454
    Thank you, and #1 does sound like a possibility. Don't think its #2, though.
  8. Regit nogara
    Regit nogara Active Member
    144
    North, North Wales
    Another place worth looking is the oil filler plug. My 2024 Aragon
    has weeped from there, but not enough to concern me.
    Tony
  9. Kinjane
    Kinjane Well-Known Member
    Oct 15, 2017
    342
    Bristol, Land of Enger
    +1 on the source being the alternator lead gromet, especially with the history of insufficient sealing permitting the oil to migrate along the loom into the reg/rectifier unit (before dripping onto the floor) in models where it’s been positioned lower than the outlet point from the casework.
  10. SeanSE
    SeanSE New Member
    Mar 19, 2025
    6
    Hanover
    Not sure what year it is, but it could be spray build-up from your chain, and it is just now starting to melt off cause of heat from the engine.
  11. learningtofly
    2,454
    Thanks, but no, it's definitely oil. I don't over-lube my chain, either.
  12. learningtofly
    2,454
    Well, it turns out that it was actually the gear position switch. The O rings were changed, but in all likelihood the cause was an error on my part in substantially overfilling the bike with oil o_O
    Anyway, lesson learnt and all sorted on the basis of goodwill by Lind Triumph (bless them).
