Rear Stand Help For Street Triple
Discussion in 'Technical Help' started by Joseph Limnios, Mar 3, 2021.
  1. Joseph Limnios
    Joseph Limnios New Member
    Feb 27, 2021
    16
    Quebec
    I need to buy a rear stand for maintenance work for my new 2014 Triumph Street Triple. Is there a specific type I need ? Do I need to install spools to be able to lift it with a stand ? As you can tell this is my first Triumph.
    Would this stand do the job ?
  2. andyc1
    Feb 4, 2017
    2,927
    N. Ireland
    That stand will do, you will need to buy spools/bobbins to screw into the swing arm. Get someone to help you the first time you try to put it on the stand! Its easy enough on your own but if your not familiar or used to putting it on the stand it can be tricky on your own.
  3. Joseph Limnios
    Feb 27, 2021
    16
    Quebec
    Are spools universal fit ?
  4. Adie P
    Adie P Crème de la Crème
    Jul 7, 2018
    3,674
    MID DEVON
    Just look for 'paddock stand bobbins (rear)' for your model and year of motorcycle. They're not universal, as such, but there are common sizes to the mounting bolt threads.
  5. andyc1
    Feb 4, 2017
    2,927
    N. Ireland
    As Aide says, look for spools specific to your bike, Most will probably fit, I think they are M8 bolts but cant remember for sure.
  6. Joseph Limnios
    Feb 27, 2021
    16
    Quebec
    My bike arrived today and it has spools installed. So I guess any stand will do, right ?
  7. Old dumb arse
    Old dumb arse Noble Member
    Mar 28, 2020
    906
    KS
    Depends first spools, that were supposed to fit weren't long enough to allow enough clearance for the stand past the swing arm. My 2019 street doesn't have a good gripping spot so a friend to spot the bike helps the first couple of times you lift
