Rear Shock Removal
Discussion in 'Speed Triple' started by bob1, Apr 28, 2025.
  1. bob1
    bob1 Noble Member
    510
    Somerset
    I intend to change out my rear shock this weekend on my 2010 speed triple in the Haynes manual it says you have to take the tank of and remove the shock from the top. when I have done this on previous bikes I do it buy taking out the back wheel undo the shock then lower the swing arm to the ground then remove the shock from below does anyone no if you can do it this way on a 2010 speed triple
  2. MightyBoosh
    MightyBoosh Senior Member
    Mar 29, 2023
    548
    I did my 2010 Sprint, very similar, and it does indeed have to go in from the top. At least l did it that way...not hard as far as it goes :)
  3. joe mc donald
    Yes i would do the same as it takes all the weight away.
  4. Bolosun
    Bolosun Noble Member
    Aug 25, 2020
    526
    343
    Crewe/Cheshire
    If I remember correctly when I removed mine, you cant move the swing arm enough to remove the shock from below.
