rear light on Thruxton not working
Discussion in 'Technical Help' started by crispey, Oct 13, 2015.
  1. crispey
    Hi All
    Got a problem that I cant seem to fix
    As above, I had a lucas 525 and eliminator on and the rear light stopped working, the brake light works, changed bulbs 3 times all fuses ok. Changed back to original triumph rear end and cluster still nothing. Everything else works apart from rear riding light.
    not a great one with electrics, I can flick a switch and change a bulb so simpletons speak if you can!
    Thanks fellas in advance
    #1
  2. crispey
    Ok! I've sorted it, like all electrics its been a pain but this was simple, eventually!
    having traced cables, re-placed the original triumph back-end checked all fuses, replaced bulbs, replaced fuses, scratched my head then my *rse, checked inside headlight cluster, did continuity checks on fuses. put it all back together and kicked the rear tyre. $I noticed that the park, position light had now gone out! so I checked that and it didn't seem to be blown, so I went back to the fuse, looked fine but decided to do a continuity check all the same, seemed fine...but wait it wasn't ,the buzzing stopped, tried again, no continuity yes continuity. chucked it put another in everything is fine, apart from my sanity. I guess somewhere along the line I must have fixed it but then blown the fuse which I had just checked so created another problem. 6 hours pfffffff!
    #2
