Quickshifter Speed Triple Rs
Discussion in 'Technical Help' started by Ian1975, Feb 22, 2019.
  1. Ian1975
    Ian1975 New Member
    Jan 24, 2019
    Weston Super Mare
    Hi all,
    I have just purchased a quickshifter for the Speedy RS, probably not thought this through, but was going to install this myself. How hard/ easy a job is this? I've read about software, removing the tank. I am now having a panic attack lol.
  2. MattChr
    MattChr Member
    Apr 23, 2018
    30
    North London
    Probably similar to installing the quick shifter on a speed r 16-18. Not sure about the software change.
    Took me about 45 mins, uses circlips which are a little fiddly. Connector is under tank which was possible without lifting it up, just fiddly to find and connect.
    Do you have the triumph Part number? All instructions on www.triumphinstructions.com
  3. FCspeed
    FCspeed New Member
    Jun 4, 2018
    5
    Belgium
    You need to upgrade the software ! and follow speciifc procedure .
