Problem With Bonnie Aftermarket Tachometer.
Discussion in 'Technical Help' started by Purple Kow, Jun 19, 2020.
  1. Purple Kow
    Purple Kow New Member
    Got the tachometer from squaredeals (good people). Several issues, stud too short, missing nut, electrical connector wrong size... all sorted. But worst of all it's not straight! Any suggestions please?
    #1
  2. Haddock
    Haddock Member
    Same here. Installation was easy enough, but seems to roughly double the rev’s....
    #2
  3. Purple Kow
    I haven't ridden it yet but it ticks over around 900rpm and seems okay when revving up. I didn't do the work myself, got a professional to do it.... more expense for a disappointing result. ☹
    #3
  4. Haddock
    Haddock Member
    Oh, you mean it’s not lined up properly?
    That should be easy to fix. If you don’t want to do it yourself, go back to the one who installed it I’d say.
    #4
  5. Purple Kow
    Thanks I'll try that when he's recovered from the frustration of getting the thing on and working. Then I'll post a pic.
    Did your's go on straight first time?
    There doesn't appear to be any room for adjusting
    #5
  6. Haddock
    Haddock Member
    Yes it did, no problems. Mine’s a 2008 Bonnie, tacho kit was for 2004(?) to 2014(?) bikes or something in that reach
    #6
  7. Wire-Wheels
    Wire-Wheels Elite Member
    California - USA
    You seem to have a tach that is set up for a 4 cylinder engine. ...J.D.
    #7
  8. Haddock
    Haddock Member
    Ok, ta, can I do something about it?
    #8
