Rocket Oil Level Check
Discussion in 'America, Speedmaster & Rocket' started by dilligaf, May 26, 2020.
  1. dilligaf
    Gonna go for a ride to Helmsley on Thursday so I’ve been giving CERBERUS :cool:a check over :)
    Looked at the owners manual because I knew that it wasn’t just checking on the dipstick :confused:
    Before I started I checked anyway and the oil was showing at the maximum mark on the dipstick :)
    Then followed the correct procedure :)
    Cold engine :)
    Start engine and run for 90seconds:)
    Wait 3minutes:confused:
    Remove dipstick and wipe clean :)
    Insert dipstick making sure it’s fully home :)
    Remove and check the level :)
    its exactly the same :confused:
    At the maximum on the dipstick :)
    Eh?:confused:
    the handbook says that it needs to be done like this because it’s a dry sump system :confused:
    bit of a palaver to get the same reading :confused:
  2. Alatamoc
    Alatamoc Senior Member
    Mar 29, 2019
    493
    Welcome to Hell.
    I've had the same thing in all three of my Thunderbirds.... almost impossible to get a reliable consistent oil level reading.
    After 5 years and lots of theories I'm still not clear why this should be.
    but it is.
    Only today I've been out looking for a patch of perfectly flat ground to get an idea of what's in the crankcase.
    I even habitually use a spirit level these days when I check the level.
    It frankly irritates the **** out if me yet I have two friends with these bikes ,one never checks his oil( good luck with that, Pal) whilst the other just checks briefly and never bothers about it. On the other hand he's done 2 k miles in 2 years and I've done 17 k. on mine.
    If you work it out fergawdsake tell me what's going on.
  3. Alatamoc
    Mar 29, 2019
    493
    So, pardon my ignorance of the new rocket, is it wet sump or dry?
  4. dilligaf
    Dry:)
  5. dilligaf
    It’s not a problem it’s just I’ve never had an engine with a dry sump system before :confused:
    What @littleade says has explained why it needs to be done like this :)
    Good enough for me :p
  6. dilligaf
    Cheers mate :)
    I knew I had to do it and now I know why:)
    First dry sump system I’ve owned :confused:
  7. Rspete
    Rspete Elite Member
    Jun 17, 2018
    1,794
    743
    Durham
    What time ya going mate?
  8. dilligaf
    Meeting @TEZ 217 on the A19 beside Nissan about 10.30 so should be there about midday ish :)
    Was gonna send ya a pm to see if you fancied it :)
  9. Rspete
    Rspete Elite Member
    Jun 17, 2018
    1,794
    743
    Durham
    Yes I do fancy it mate, I'm on call at work so don't start until 4 so gives us/me plenty of time. :laughing:
  10. dilligaf
    You wanna come over and ride down with us or just see you there :)
    I’ll be social distancing so no cuddles pet :sob::kissing_heart:
  11. Rspete
    Rspete Elite Member
    Jun 17, 2018
    1,794
    743
    Durham
    Don't want to come now, that's all I was coming for...... GOD DAMN SOCIAL DISTANCING :mad: :joy:
    I'll come down with you mate.
  12. Kenbro
    Kenbro Noble Member
    Jul 9, 2019
    828
    Manchester, UK
    So, can, and does oil drain into the sump when left standing, or is it just a possibility?
    And if it is a possibility, but not a given, why?
    I remember old Brit. bikes had a gold line on the outside of the oil tank as a ‘fill to level’ and you peered into the tank neck and estimated where to line was on the outside.
    There was always plenty of room between the line and the top of the tank.
    Didn’t seen to matter if oil had drained into sump.
    Ken.
  13. dilligaf
    Feckin hell we’re going backwards :eek::p
  14. dilligaf
    That’ll be on the next model :p
  15. Don the Don
    #15 Don the Don, May 28, 2020
  16. Rocker
    Rocker Elite Member
    May 1, 2016
    1,662
    Suffolk
    Some modern bikes do as well like my MT01 and Aprilia RSV
  17. speeder
    speeder Noble Member
    Jan 3, 2019
    406
    313
    dorset
    My old 650 beeza has a dry sump and it's dead easy to check the oil.......simply remove filler cap and look at the oil level in the tank!
    You're right we have gone backwards in some respects!
Similar Threads - Oil Level Check
  1. chuk
    4
    8,479
  2. Hugh Murray
    4
    2,594
  3. TST955
    4
    2,109
  4. Chris Curran
    5
    1,710
  5. Hubaxe
    6
    1,035
