Oil Leakage In The Electrical Coil Compartment
Discussion in 'Technical Help' started by Erwin Berends, Jul 4, 2025.
  1. Erwin Berends
    Erwin Berends New Member
    Jul 4, 2025
    Hi,
    Since 2 months ago my speedmaster 865 from 2007 runs on one cilinder sometimes. This I frixed due to replacing the CDI. It runs on two cilinders now, but sometimes during a ride the engine stothers and come to a stand still. It doesn't start directly, but after waiting a while and starting it again, it runs. A Triumph mechanic advised me that maybe the pick up coil is also failing. I decided to have a look and removed the engine cover of the electrical coil where the pick up coil is situated. When I removed the cover I freaked out. The whole chamber was covered with oil. This quite explains the periodic stand stills of the engine, because of an oil film between the pick up and the Altinator. Now it starts and runs fine, but I didn't drove iot yet. I cleaned it and want to do a short ride to see how much oil is leaking, but to be honnest I need to fix this. Is there an oil seal behind the altinator on the Crankshaft. I can't find the partno on any parts site?? Or is the sealing between the Cranckshaft and the electrical compartrment otherwise solved. I hope someone knows
    regards Erwin
  2. Wattie
    Wattie Well-Known Member
    Feb 25, 2020
    354
    Are you sure you're not worrying about something that is normal?
    I don't have an 865 but this video on a T100 pick up coil did have quite a bit of oil in there
    plus I just checked a thread on the same subject on triumph rat and they suggested it is normal to have oil there.
    https://www.triumphrat.net/threads/oil-in-alternator-area-normal.839386/
    My 2002 T300 trophy had some oil in the casing where the pick up sensor is when I replaced it (it has a separate alternator unlike the 865).
  3. joe mc donald
    @Erwin Berends Welcome to the family. Do hit the upload a file button bottom right and show of the bike.
  4. 243jimb
    243jimb Member
    Nov 27, 2018
    Canada
    There is supposed to be oil in there. It does not affect the sensor for the PU coil.
