Oil Check/sight Glass Question, Speed Twin.
Discussion in 'Technical Help' started by Golgotha, Jun 24, 2021.
  1. Golgotha
    Golgotha Guest
    #1 Golgotha, Jun 24, 2021
    I know a proper oil fill reading is performed w/the bike standing upright, vertical, and off the kickstand, but when the bike is leaning on the stand, should there not still be some indication of oil in the glass? I just got an oil change and now while on the stand I can see into the sump perfectly… absolutely no indication of oil. I can also look down in through the fill cap and the sump appears to be practically bone dry. When stood up I get a reading. I remember looking into the sight glass previously on the stand and the glass still had an oil level visible, even if inaccurate. .
    The check engine light is now on too so this compounds my concerns.
    Thanks in advance…! -Gg
  2. Yorkshireman
    I’ve never, as far as I can recall, had a bike that has shown oil in the sight glass on the side stand. If it was a dealer oil change they are notorious for putting the “required” amount in regardless of whether the final level is where it should be on the dipstick or sight glass.
  3. sprintdave
    1,621
    If it was my bike I would get a mate to hold the bike upright while I checked the level. It wouldn't be the first time a garage got the level wrong, either under or overfilling. On my bike, T509 Speed Triple, the level drops quite a lot on the side stand. Don't run the bike till you have made sure.
  4. Golgotha
    Golgotha Guest
    #4 Golgotha, Jun 24, 2021
    Good to know. It was indeed a dealer who did the work.
    So is a bit extra oil not a bad idea, even if it registers on the glass while parked/on the stand?
    I was returning home from the dealer after(yet another) warranty issue. I figured “what the hell” and had them do a change as it couldn’t hurt… Wound up costing $216 bucks. Check engine light came on and after determining it wasn’t going to correct itself I pulled into a station. That’s when I checked the sight glass.
    The bike went straight back to the dealer. They were good enough to dispatch a trailer and haul it back.
  5. nickjaxe
    nickjaxe Active Member
    Sep 2, 2020
    Cheshire UK
    Sometimes its not easy to see the oil...but are you looking soon after the engine has ran.....needs to rest and let all the oil return to the sump.
    Dont start the motor till you have found out if the oil is ok.
  6. Golgotha
    Golgotha Guest
    (Thread Resurrection)
    Proper reading is around 1/2-way across the glass, upright and cold, right?
  7. brown mouse
    brown mouse Elite Member
    Sep 15, 2018
    2,288
    943
    East Midlands, UK
    #7 brown mouse, Oct 20, 2021
    Upright and warm surely? My owners manual says...
    An accurate indication of the level
    of oil in the engine is only shown
    when the engine is at normal
    operating temperature and the
    motorcycle is upright (not on the
    side stand).​
    I have to get Mrs Mouse to sit on the bike to hold bike upright so I can check the level sight glass that's hidden behind the foot control mounts. Oh for the good old days of easy to use dipsticks that you could get at whilst sitting on bike...
    Edit:
    The full instructions from my owners manual (an probably yours ;)) is...
    To inspect the oil level:
    • Start the engine and run at idle for
    approximately five minutes. Stop
    the engine and wait for at least
    three minutes to allow the oil to
    settle.
    • Note the oil level visible in the sight
    glass.
    • When correct, oil should be visible
    in the sight glass at a point midway
    between the upper (maximum) and
    lower (minimum) markings on the
    sight glass.​
    There's also a diagram showing what the minimum and maximum limits are.
  8. Chainbiter
    Chainbiter Well-Known Member
    Aug 6, 2021
    104
    83
    Our bathroom mirror was shamelessly stolen by me.
    The circular base was removed and securely stored (binned) and the upright section with the mirror was zip tied to a piece of timber.
    I can now sit on the bike keeping it upright and angle the mirror so I can see the oil level.
    And yep, I was grumbled at but I thought it was a worthy cause :)
  9. nickjaxe
    Sep 2, 2020
    Cheshire UK
    I like it....great idea.
