Right so I have a triumph daytona 650 and it runs fairly well, never any major problems but........ I have just noticed when it is just nicely ticking over in neutral the headlights and dash lights flicker, nothing to serious but today when I went out on it the speedo and in fact entire dash constantly kept on resting itself as if I just turned it on. This didn't effect the way it rode, so in my lack of knowledge I assume it is an electrical problem of some sort. Please help before I get stranded some where
I would be doing two things with a multi-meter set on 0-20v DC: 1. Without turning anything, on the bike - measure the voltage across the battery + and - terminals. A good battery should read about 12.7 volts; 2. Now with the engine ticking over - measure the voltage across the battery terminals. If the bike's charging circuit is working properly it should read 13.5 to 14 volts.
Could it be a dodgy earth connection somewhere, that can sometimes cause these stupid little problems. Could be worth checking the earth connections for corrosion/tightness
It's getting worse now. All lights are flickering rear and front. I will try and post video if I can, also I had starter problems a few weeks ago and took it to the garage, the guy said a relay was buggered and swapped it for a new one which he said was the same type but not original to the bike.
Yes I would agree with Al on this bad earth or loose connection, possible corroded semi broken wire within its plastic sheath a bit of a ball breaker but once all earth's checked it will be a case of checking each wire visually and with a meter.
That sounds like the charging circuit is working fine. Having seen the video I would say you have a faulty circuit or LCD screen. See how much a clock set goes for on Ebay.
So, as an act of desperation I took all fuses and relays out gave everything clean and check replaced everything and the problem has been solved it appears. Maybe a loose fuse or something?
Hi Gaz did this effect all lights on bike even road lights, i am glad you corrected the fault but i always like to find what the exact fault was if i can.
Yep all the lights and at one point the rear light was flickering wildly, I think the only lights not affected were the indicators.
And they are meant to flicker LOL. glad its OK now but that seams to be a main supply cable problem to me.
Well I shall keep an eye on it, I even feel that the garage may have detected my lack of knowledge and did to get more money out of me.....
