Newby Needs Some Help With 140v
Discussion in 'Newbies Hangout' started by trevet, Apr 24, 2020.
  1. trevet
    trevet New Member
    Apr 24, 2020
    2
    Hi new to this forum, don't have a running bike at the moment, in the process of trying to restore a 140V.
    live in Hertfordshire UK. Need to find best way of aligning camshaft bearings.
    Trevet
  2. Wessa
    Hi and welcome.....
  3. trevet
    trevet New Member
    Apr 24, 2020
    2
    Thanks it was auto filled how do I get rid of it
  4. Helmut Visor
    Hi Trevet, and welcome in :cool::cool:
    As has been said, hover your cursor over your profile icon top right, down to personal details then scroll down to location, change and save ;);)
  5. dilligaf
  6. Tiglet
    Hello Trevet and welcome to the forum :)
  7. Don the Don
    Hi and welcome
  8. Hobnail
    Hobnail Senior Member
    Jan 4, 2020
    1,245
    USA
    Welcome from Iowa, USA. Are you referring to timing and not bearing alignment? The bearings fit in the case housing and I am not aware of alignment. Timing, on the other hand, is very important and particular.
  9. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    Basically its a case of line boring them once they have been pressed in with the cases bolted up and crank installed however i have renewed plenty without doing that as coupled with minor misalignment when bolting up the cases which are usually taken care of by the crankshaft and cams and the fact that most replacement bearings are supplied to size these days you can usually get away without...welcome to the best bike forum on the net.:)
  10. Vulpes
  11. trevet
    trevet New Member
    Apr 24, 2020
    2
    Thank for the info, I had assumed that a tool was required, as all I see on youtube show a tool being used, which I have been unable to find on any web site.
  12. trevet
    trevet New Member
    Apr 24, 2020
    2
  13. darkman
    I use a factory line reamer after pressing in the four bushes i use a stainless steel ball bearing to size the timing side and the then ream the primary side with the cases bolted together.
  14. David Cooper
    Hello and welcome to the forum Trevet.
  15. joe mc donald
    Trevet
    Welcome to the family. Do a build in the rebuild and projects section with pictures using the upload a file button bottom right corner and let the inmates take the journey with you.
    Regards & Luck.
  16. Easy Tiger
    Easy Tiger Elite Member
    Jan 2, 2020
    1,585
    Wirral England
    Welcome to the forum mate.
  17. Dartplayer
    Hi Trivet and welcome to the forum :cool:looking forward to seeing your project progress
