Neutral Light Issue
Discussion in 'Technical Help' started by Nigellynch, Aug 23, 2019.
  1. Nigellynch
    Nigellynch New Member
    Aug 9, 2019
    Peterborough
    Hi there all,
    can you help. My neutral light on my 1994 Daytona 900 works fine on start up and when the bike is cold, when it warms up it stops illuminating. I have followed the manual to check the operation of the switch (when hot and not working) I disconnected the wire leading to the switch and earthed it - the light comes on !
    So that tells me the switch is malfunctioning. I replaced the switch with a new one - guess what ? the same - no light when engine is hot !!!
    I noticed when checking the switch by earthing the feed wire, caused a clicking noise under the seat area at the same time as the neutral light came on, which sounds like a relay noise. However I cannot see on the wiring diagram a relay for this neutral light switch.
    I have eliminated the switch by changing it. I wonder if the gear selector is worn where the switch contacts it ??
  2. sprintdave
    May 25, 2014
    1,682
    The neutral light issue is common on all T300 models. I believe a common quick fix is a thin washer underneath to shim up the switch
  3. MICK64
    MICK64 Active Member
    Sep 15, 2020
    89
    NEW FOREST. ENGLAND
    Where is the switch please.
  4. capt
    capt Elite Member
    May 8, 2016
    3,051
    western Australia
    Under side of the gearbox. Follow the wire , it is usually mid box in a deepish recess.
  5. MattGaydon
    MattGaydon Noble Member
    Jun 11, 2015
    1,097
    Godalming
    Did this sort the issue??
  6. Yorkshireman
    Looks like another one who joined just to ask a tech question and not seen since (2yrs+):(
    Mick64 will be along soon tho :p
  7. MICK64
    Sep 15, 2020
    89
    NEW FOREST. ENGLAND
    Right here, I been expecting you. :)
  8. MattGaydon
    Jun 11, 2015
    1,097
    Godalming
    Haha so did you do this fix to your bike?
